06-09-2005 05:48 PM - edited 03-03-2019 09:47 AM
Hi ALL,
Can anybody help me out in configuring VPN SITES for 8 branchoffices
from head quaters and dll(digital leased line) as backuplink with reference
to the cisco link.That would be very useful as iam going to configure a new site.
Please help me out in knowing the concepts and configuration for the same.
Awaiting for the concepts and configuration for vpn.
SHAHUL
06-09-2005 08:27 PM
YOu might want to look at DMVPN. Very stable and flexible VPN sol.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110ba1.html
What routers have you decided to use at the edge ?
06-10-2005 06:45 PM
at your branch offices, are you terminating the ipsec lan-lan tunnel on a firewall or a the router? for your vpn connection, you could use gre over ipsec to pass your routing protocol. your dll is always up, so you could also enable routing on that interface. you'd just have to tune your routing protocol to prefer routes from the primary link, in your case the vpn link.
