vpn pptp
I configure pptp vpn on cisco 2811, when users connected to our head office as remote vpn client they did not get default gateway and my local DNS.
can anyone help in these problem, how i can assign my default gateway and mylocal dns to remote vpn client.
regards,
wang baojun
hello ,
below pptp config you can reference to .
vpdn enable
vpdn-group pptp
accept-dialin
  protocol pptp
  virtual-template 1
interface Ethernet0/1
description connect to isp
ip address 202.18.14.148 255.255.255.248
ip nat outside
load-interval 30
full-duplex
interface Virtual-Template1
ip unnumbered Ethernet0/1
peer default ip address pool 1
ppp authentication pap chap
ppp ipcp dns 152.104.168.162 152.104.228.251
ip nat inside
ip local pool 1 192.168.104.112 192.168.104.115     #### assign lan ip address for remote client
wang baojun
hello ,
vpdn enable
vpdn-group pptp
accept-dialin
  protocol pptp
  virtual-template 1
ip nat outside
load-interval 30
full-duplex
ip nat inside
Thanks wang
i am testing that one only.
regards
Dear Wang,
        yes vpn remote client get local dns ip address.  But i have one question that default gateway is 0.0.0.0 and subnet mask is getting 255.255.255.255.
can you help to define subnet mask should be "C" class and default gateway from the vpn test pool ip address.  It is possible to assign default gateway and subnet mask to remote vpn client.
regards,
hello ,
pptp vpn , remote client get the internal ip address ,and the mask is 255.255.255.255 . this is define by pptp , we cannot change anything.
0.0.0.0 mean that all data include vpn flow and internet from pc to destination ,should forward to remote router .
