VPN SETUP!!!!
dlgoodson
What is needed for complete connection with a cisco PIX 515 and cisco vpn client software for windows v.4 & up?
kerek
Level 4
Level 4
Let's take a look at the following link:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008088a1e0.shtml
Hope it helps, rate if does
Krisztian
purohit_810
Level 5
Level 5
That is depend upon you, how would you configure.. Possible scenario as below.
1) If you have few clients mean username and password you can create locally IPSEC username.
2)If you have more username and password than you can create it in ACS (RADIUS and TACACS+ Server) and authenticate bythem.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009442e.shtml
Dharmesh Purohit
