VPN-Tunnel in VPN-Tunnel for Case Studie
dennisvdt
Hello Guys, i am wondering if there is a methode to make a Tunnel in a Tunnel. Something like a Tunnel between two ASA Firewalls and then a Tunnel between two Router. PC0 and PC1 should be Tunneling though the Firewalls and then though the Routers.
Permit ip 192.168.20.0 255.255.255.0 193.168.20.0 255.255.255.0
the ACL is same in both router ? this is why IPsec tunnel is failed.
also the source and destiantion is same in ACL ?
5 Replies 5
no specific method,
config Tunnel 1 between R
Tunnel 1 ACL must permit the subnet of Out of ASA FW
config tunnel 2 between ASA FW
Tunnel 2 ACL must permit the subnet of IN of ASA FW
now you have Tunnel in Tunnel
dennisvdt
ACL Between Router Permits any ips
ACL Between ASA FR Permits in subnets
Tunnel from Firewall to Firewall works, but from Router to Router does not Tunnel just routs it though.
share config here
Router0 10.10.5.2
Router1 10.10.5.3
Crypto isakmp enable
Crypto isakmp policy 10
Authentication pre-share
Encryption aes 256
Encryption aes 256
Hash sha
Hash sha
Group 5
Group 5
exit
exit
Crypto isakmp key cisco address 10.10.5.3
Crypto isakmp key cisco address 10.10.5.2
Crypto ipsec transform-set vpnset esp-aes 256 esp-sha-hmac
Ip access-list extended vpnacl
Permit ip 193.168.20.0 255.255.255.0 192.168.20.0 255.255.255.0
exit
exit
Crypto map vpnmap 10 ipsec-isakmp
Match address vpnacl
Set peer 10.10.5.3
Set peer 10.10.5.2
Set transform-set vpnset
exit
exit
Int se0/1/0
Int se0/1/0
Crypto map vpnmap
Crypto map vpnmap
