VPN
Hamid Amir
Question
I have a Cisco 877 router which connects my network to the Internet using an ADSL line, static IP address and NAT; the IOS version is 15.
Everything is working ok, but I'd like to configure this router to be a VPN server, to be able to connect to the network from the outside.
letting single remote computers access the internal network
I can connect  to my vpn from home using router ip as server name in vpn client (is this wright) but I can not from the outside using public internet
And, finally: how to set up this?
my config
Current configuration : 5563 bytes
! Last configuration change at 15:16:15 UTC Mon Aug 28 2017 by me
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
aaa authentication login default local
aaa authentication login vpn_xauth_ml_1 local
aaa authentication login sslvpn local
--More--
*Aug 28 15:18:19.652: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
*Aug 28 15:18:19.660: %LINK-3-UPDOWN: Interface Virtual-Access3, changed staaaa authorization exec default local
aaa authorization network vpn_group_ml_1 local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-4137654229
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4137654229
revocation-check none
rsakeypair TP-self-signed-4137654229
no ip dhcp use class
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.0 192.168.1.99
ip dhcp pool vlan1
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 90.207.238.97 90.207.238.99
ip domain name yourdomain.com
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ1843C42Y
license boot module c800 level advipservices
vtp domain SKYBB
vtp mode transparent
username me privilege 15 secret 5 $1$9BoE$Zz74ymPxsv0oQu/5NTfdj.
username she secret 5 $1$HjSK$puFAwr96lu1Pdmdzt/4tB.
controller VDSL 0
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp client configuration group CCLIENTvpn
key firewallvpn
dns 10.0.0.10
pool VPN-Pool
acl vpn_resources
max-users 5
crypto isakmp profile vpn-ike-profile-1
match identity group CCLIENTvpn
client authentication list vpn_xauth_ml_1
isakmp authorization list vpn_group_ml_1
client configuration address respond
virtual-template 2
crypto isakmp profile VPN-Profile-1-ike-profile-1
match identity group group2
match identity group group1
virtual-template 2
crypto ipsec transform-set encrypt-method-1 esp-3des esp-sha-hmac
mode tunnel
crypto ipsec profile VPN-Profile-1
set transform-set encrypt-method-1
set isakmp-profile VPN-Profile-1-ike-profile-1
interface ATM0
no ip address
ip policy route-map voip
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Virtual-Template2 type tunnel
ip unnumbered Dialer0
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN-Profile-1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname 8059afb35580@skydsl
ppp chap password 0 df59b51e
ppp pap sent-username 8059afb35580@skydsl password 0 efrtyuie
ppp ipcp dns request
no cdp enable
ip local pool VPN-Pool 192.168.0.20 192.168.0.25
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list any interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended any
permit ip any any
ip access-list extended vpn_resources
permit ip 192.168.0.0 0.0.0.255 any
no cdp run
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
49 Replies 49
Francesco Molino
Based on your config, the following profile is the right one: vpn-ike-profile-1
I want to understand why are you configuring your ipsec profile to point to the isakmp profile VPN-Profile-1-ike-profile-1 that's not the correct one. I mean on this profile VPN-Profile-1-ike-profile-1, you refer to some identities that aren't not existing and missing the the client authentication.
I would be interested to see how you can connect from home.
Let's correct the profile with those commands:
no set isakmp-profile VPN-Profile-1-ike-profile-1
set isakmp-profile vpn-ike-profile-1
And give it a try.
I'll review it when I'm back home from a laptop to be sure I didn't missed something on your config.
If you can do that test before it would be great.
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco
I did the change you suggested but still I can not coneect from outside.
i get error message Vpn server do not respond
please see below.
can you help ?
cisco ccp
Router#sh ip int brief
ATM0 unassigned YES NVRAM up up
Dialer0 94.10.200.233 YES IPCP up up
Ethernet0 unassigned YES NVRAM administratively down down
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset up up
FastEthernet3 unassigned YES unset down down
NVI0 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset up up
Virtual-Access3 94.10.200.233 YES unset up up
Virtual-Access4 94.10.200.233 YES unset up up
Virtual-Template2 94.10.200.233 YES unset up down
Vlan1 192.168.1.1 YES NVRAM up up
Version:1.0 StartHTML:000000231 EndHTML:000005392 StartFragment:000000392 EndFragment:000005360 StartSelection:000000392 EndSelection:000005360 SourceURL:file:///C:/Users/Administrator/Desktop/VPNTroubleshootingReport.htmlVPN Troubleshooting Report Details
Router Details
AttributeValue
Router ModelC887VA-K9
Image Namec800-universalk9-mz.SPA.153-3.M3.bin
IOS Version15.3(3)M3
HostnameRouter
Test Activity Summary
ActivityStatus
Checking Easy VPN Server configuration...Successful
Checking dependent components...Successful
Checking Firewall...Successful
Test Activity Details
ActivityStatus
    Interface :Virtual-Template2
    Tunnel Mode:ipsec ipv4
    Interface physical status :Up
    Interface IP address Type :Dialer0
    Interface :Dialer0
    Line protocol status :Up
    Interface IP address Type :Easy IP
    Checking IPSec Profile:VPN-Profile-1
    ISAKMP Profile Association:Configured
    Transform set :Configured
    Checking IKE Profile:vpn-ike-profile-1
    Group Match Identity:Configured
    Authorization Policy:Configured
    Checking IKE
    IKE Policies : Configured
    Policies with pre shared key authentication method : Configured
    IKE configuration status : Valid
    Checking AAA
    AAA status : Enabled
    AAA authorization : Not configured
    AAA authentication : Not configured
    Checking Local Group Policies
    Global address pool : Not configured
    Group Name : CCLIENT-VPN
    Key : Configured
    Local address Pool : Configured
Troubleshooting Results
Failure Reason(s)Recommended Action(s)
Ok You can access https to your public IP but I think it's an authentication error. Can you do: aaa authorization network CCLIENTvpn local
And test it please ?
Francesco
Hi Francesco Molino
Did not work.
I have Virtual-Template2 prot down.
any other suggestion please
on a side note, try and add the below in global configuration mode:
webvpn sslvpn-vif nat inside
Is your purpose to also have the remote users access resources in the local (192.168.1.0/24) network ?
Hi George
Yes i want the remote users access resources in the local (192.168.1.0/24) network. I did apply your configuration but i get the message below
% IP NAT configuration is applied to contexts without Vt.
% But please use virtual-template to configure this feature.
Kind Regards
Hamid
I have made a few adjustments (marked in bold) to your original configuration, see if you get this to work.
For simplicity, the VPN pool uses addresses from your local LAN, which are subsequently excluded from NAT.
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
ip dhcp pool vlan1
import all
ip cef
no ipv6 cef
vtp domain SKYBB
controller VDSL 0
encr 3des
group 2
encr 3des
hash md5
group 2
key firewallvpn
dns 10.0.0.10
pool VPN-Pool
acl vpn_resources
max-users 5
virtual-template 2
virtual-template 2
mode tunnel
interface ATM0
no ip address
atm vc-per-vp 64
pvc 0/38
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
ip unnumbered Vlan1
interface Vlan1
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip local pool VPN-Pool 192.168.1.200 192.168.1.210
ip http server
ip dns server
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.200
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.201
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.202
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.203
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.204
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.205
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.206
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.207
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.208
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.209
deny ip 192.168.1.0 0.0.0.255 host 192.168.1.210
permit ip 192.168.1.0 0.0.0.255 any
no cdp run
control-plane
line con 0
Hi George
I did apply your configuration but still doesn't work.
Kind Regards
Hamid
I'm sorry but did you do the change I suggested:
Can you send the config you have right now please?
Except that I don't see any missconfiguration. There was 1 on the virtual-template that thanks to Georg it's been corrected.
Francesco
Hi Francesco
Yes i did the  change you and George suggested .
and below exaclly the configuration at thge moment.
Kind Regards
Hamid
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#crypto isakmp profile vpn-ike-profile-1
Router(conf-isa-prof)#
Router(conf-isa-prof)# no match identity group CCLIENTvpn
Router(conf-isa-prof)#end
Router#
*Aug 31 06:12:45.193: %SYS-5-CONFIG_I: Configured from console by faieza on cons ole
Router#wr
Building configuration...
[OK]
Router#sh run
Current configuration : 6324 bytes
! Last configuration change at 06:12:45 UTC Thu Aug 31 2017 by faieza
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
aaa authorization network CCLIENT-VPN local
crypto pki certificate chain TP-self-signed-4137654229
certificate self-signed 01
quit
ip dhcp pool vlan1
import all
ip cef
no ipv6 cef
vtp domain SKYBB
username faieza privilege 15 secret 5 $1$9BoE$Zz74ymPxsv0oQu/5NTfdj.
username admin secret 5 $1$HjSK$puFAwr96lu1Pdmdzt/4tB.
controller VDSL 0
encr 3des
group 2
encr 3des
hash md5
group 2
crypto isakmp client configuration group CCLIENT-VPN
key firewall.cx
dns 10.0.0.10
pool VPN-Pool
acl vpn_resources
max-users 5
match identity group CCLIENT-VPN
virtual-template 2
virtual-template 2
mode tunnel
interface ATM0
no ip address
atm vc-per-vp 64
pvc 0/38
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
ip unnumbered Vlan1
interface Vlan1
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname 8050afb35580@skydsl
ppp pap sent-username 8050afb35580@skydsl password 0 ef59851e
no cdp enable
ip http server
ip dns server
permit ip any any
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
scheduler allocate 20000 1000
end
a few things are still incorrect (marked in bold):
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
quit
ip dhcp excluded-address 192.168.1.200 192.168.1.210
ip dhcp pool vlan1
import all
ip cef
no ipv6 cef
vtp domain SKYBB
controller VDSL 0
encr 3des
group 2
encr 3des
hash md5
group 2
key firewall.cx
dns 10.0.0.10
pool VPN-Pool
acl vpn_resources
max-users 5
virtual-template 2
virtual-template 2
mode tunnel
interface ATM0
no ip address
atm vc-per-vp 64
pvc 0/38
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
ip unnumbered Vlan1
interface Vlan1
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
--> no ip local pool VPN-Pool 192.168.0.20 192.168.0.25
ip http server
ip dns server
permit ip any any
--> no permit ip 192.168.0.0 0.0.0.255 any
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
--> no webvpn sslvpn-vif nat inside
Hi George
Sorry about that; i couldnt see bold text in outlook.
still not working
Below the updated configuration as you suggested.
kind Regards
Hamid
Router(config)#ip access-list extended vpn_resources
Router(config-ext-nacl)#no permit ip 192.168.0.0 0.0.0.255 any
Router(config-ext-nacl)#end
Router#
*Aug 31 15:41:41.265: %SYS-5-CONFIG_I: Configured from console by faieza on consolewr
[OK]
Router#sh run
Current configuration : 6260 bytes
! Last configuration change at 15:41:41 UTC Thu Aug 31 2017 by faieza
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
ip dhcp pool vlan1
import all
ip cef
no ipv6 cef
vtp domain SKYBB
controller VDSL 0
encr 3des
group 2
encr 3des
hash md5
group 2
key firewall.cx
dns 10.0.0.10
pool VPN-Pool
acl vpn_resources
max-users 5
virtual-template 2
virtual-template 2
mode tunnel
interface ATM0
no ip address
atm vc-per-vp 64
pvc 0/38
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
ip unnumbered Vlan1
interface Vlan1
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username 8050afb35580@skydsl password 0 ef57b51e
no cdp enable
ip http server
ip dns server
permit ip any any
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
end
there is still a mistake in your access list. Remove 'permit ip any any' as the first line, as this line renders the access list basically useless:
--> no permit ip any any
Hi Gerorge
I updated my configuration but still i cannt connect from outside.
kind Regards
Hamid
no cdp run
control-plane
