VPN
mikntwd49508
Hardware: 2811 router
Currently using Cisco VPN software to establish VPN connection from outside to corporate resources.
Problem: everyone has same *.pcf profile.
Solution: How do I create new Cisco *.pcf profile and configure it on Cisco 2811?
pradeepde
Level 5
Level 5
I think the connection entry specifies a connection entry profile (.pcf file). To configure the security association for one or more PCFs or the default security association for all PCFs, use the cdma pdsn secure pcf command
