VRF Aware NAT route leaking cisco ios
georgehewittuk1
I know with Cisco IOS-XE there is the VASI configurations but with Cisco IOS what options do we have to leak traffic between VRFs on same router and NAT?
I'm aware of implementing a global static route into a VRF and NAT but for inter-vrf would it need to be achieved through an export map or another configuration example I'm missing?
Thanks all
George
not sure if that is what you are after, but have a look at the link below:
https://community.cisco.com/t5/security-documents/nat-with-vrf-ios-vs-ios-xe/ta-p/3156555
Deepak Kumar
yes, you will require import and export command to archive the same.
Here is an example: https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200158-Configure-Route-Leaking-between-Global-a.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
Are these separate vrf/s both internally to you network? - can you share a topology diagram of your intentions and preferably attach a file with the current configuration of the NAT/VRF rtr(s)
Kind Regards
Paul
