VRF Default Gateway missing
Thomas Johnston
I'm testing some things out in VIRL and having some issues. I'm not a routing expert and am just getting started with VRFs. My issue is I cannot get the VRF default route to populate no matter what I'm doing. I do plan on putting this into place in production eventually.
In my simple test setup I have 2 IOSvL2 switches (which allow VRF) connected together with a /24 network. I can ping between them. I then have a test VLAN and VRF setup. I put a route in to VRF from Switch 1 to switch 2 over the shared link.
I know this is something stupid easy to figure out...
Switch 1
ip vrf Guest
 description Guest VLANs
interface GigabitEthernet0/1
 description to Switch-2
 no switchport
 negotiation auto
interface GigabitEthernet0/2
 description (to unmanaged switch to get vlan up)
 switchport access vlan 321
 switchport mode access
 media-type rj45
 negotiation auto
interface Vlan321
 description Guest Test
 ip vrf forwarding Guest
 ip address 192.168.2.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
ip route 0.0.0.0 0.0.0.0 192.168.1.2
ip route vrf Guest 0.0.0.0 0.0.0.0 192.168.1.2
switch-1#sh ip route vrf Guest
Routing Table: Guest
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is not set <--------WHY?
      192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.2.0/24 is directly connected, Vlan321
L        192.168.2.1/32 is directly connected, Vlan321
switch-1#show int vlan321
Vlan321 is up, line protocol is up
Hardware is Ethernet SVI, address is 5e00.0000.8141 (bia 5e00.0000.8141)
Description: Guest Test
Switch 2
 no switchport
 ip address 192.168.1.2 255.255.255.0
 negotiation auto
switch-2#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/5/9 ms
switch-2#
Why isn't the VRF populating a default gateway in the system?
Thanks for any help!
9 Replies 9
Hello
try adding global to the end of the default vrf route
Ip vrf Guest 0.0.0.0 0.0.0.0 192.168.1.2 global
Kind Regards
Paul
Unforuntly that did not work for me. Same end results.
switch-1#show ip route vrf Guest
Hello
That should populate your vrf Guest rib  - wondering if this is VIRL related?
Is that svi up?
Kind Regards
Paul
The command Paul suggested should be:
ip route vrf Guest 0.0.0.0 0.0.0.0 192.168.1.2 global
Bear in mind that you will need a route in the other direction, as traffic coming back will require a lookup in the global routing table.
ip route 192.168.2.0 255.255.255.0 vlan321
Hello harold
This would be for the return traffic to know how to reach the vrf network, but it shouldn't be needed to populate the vrf rib with a default route should it?
Kind Regards
Paul
Hello
For my own sanity --
test#sh run | sec ip route
ip route vrf stan 0.0.0.0 0.0.0.0 10.1.12.2 global
test#sh ip route static
test#sh ip route vrf stan static
S*   0.0.0.0/0 [1/0] via 10.1.12.2
test#sh ip route vrf stan | b Ga
Gateway of last resort is 10.1.12.2 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.13.0 is directly connected, FastEthernet0/1
Kind Regards
Paul
Hi Paul,
That is correct.
I was just stating that this would be needed for a complete solution.
a.alekseev
Level 7
Level 7
ip vrf Guest
 rd 1:1
There is no need for a route distinguisher in a VRF lite scenario.
