vrf-lite
Sunny Banks
Hello gentle people,
I'm labbing a vrf-lite setup and I feel the config is good. Per the topology, CORP works but PROD does not. The networks behind the core neighbour are pingable for CORP but not PROD. Here's the config for R1 & R2 : -
R1#show run
Building configuration...
Current configuration : 2183 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
ip vrf CORP
ip vrf PROD
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip tcp synwait-time 5
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface GigabitEthernet0/0
ip vrf forwarding CORP
ip address 10.10.10.1 255.255.255.0
duplex full
speed 1000
media-type gbic
negotiation auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet3/0
ip vrf forwarding PROD
negotiation auto
interface GigabitEthernet4/0
no ip address
negotiation auto
interface GigabitEthernet4/0.1
encapsulation dot1Q 10
ip address 30.30.30.1 255.255.255.252
interface GigabitEthernet4/0.2
encapsulation dot1Q 20
ip address 30.30.30.5 255.255.255.252
interface FastEthernet5/0
no ip address
shutdown
duplex half
interface GigabitEthernet6/0
no ip address
shutdown
negotiation auto
router ospf 1 vrf PROD
log-adjacency-changes
network 10.10.10.0 0.0.0.255 area 0
network 30.30.30.0 0.0.0.3 area 0
router ospf 2 vrf CORP
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#show run
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
ip vrf CORP
ip vrf PROD
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
no ip address
shutdown
duplex auto
ip address 20.20.20.1 255.255.255.0
duplex full
speed 1000
media-type gbic
negotiation auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
negotiation auto
no ip address
negotiation auto
ip address 30.30.30.2 255.255.255.252
ip address 30.30.30.6 255.255.255.252
no ip address
shutdown
duplex half
no ip address
shutdown
negotiation auto
network 20.20.20.0 0.0.0.255 area 0
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
I've taken multiple looks and it seems good. Am I missing something obvious?
Thanks in advance,
Sunny
2 Accepted Solutions
Your PROD OSPF configuration is incorrect. Your network statement doesn't cover the interfaces in the PROD VRF. I'm assuming you also don't have PROD OSPF neighborship. Change it to include the .5 and .6 interfaces respectively/ Once you change that it should work.
-David
at first glance you OSPF configuration is incorrect:
you are advertising 30.30.30.0/30 network when you should be advertising 30.30.30.4/30 network
network 30.30.30.4 0.0.0.3 area 0
Please remember to select a correct answer and rate helpful posts
5 Replies 5
Nothing wrong in your config still
There is one piece missing' the RD of vrf
You need to add RD for each VRF
Then wr config' close lab and open it again and check
As my colleague mention the subnet and mask is also wrong you use ""network 30.30.30.0 0.0.0.3"" but you need to use ""network 30.30.30.4/30""
MHM
-David
I reply to your second post' please check my reply
MHM
Sunny Banks
Thank you all. It was indeed the PROD ospf network statement.
