VRF Routes Redistribute
feroz syed
Level 3
Level 3
Attached topology screenshot, BGP enabled on PE routers only (2 3 5). Router9 and Router2 Ebgp neighbor...Router2 can see route  9.9.9.9 on its vrf BLACK,but it not passing to other PE routers 5 and 3...router 9 can see other customer routes from RED and BLUE.
R2#sh run | sec router bg
router bgp 100
bgp log-neighbor-changes
neighbor 3.3.3.3 remote-as 100
neighbor 3.3.3.3 update-source Loopback0
neighbor 5.5.5.5 remote-as 100
neighbor 5.5.5.5 update-source Loopback0
neighbor 12.12.12.1 remote-as 9
address-family ipv4
neighbor 3.3.3.3 activate
neighbor 5.5.5.5 activate
no auto-summary
no synchronization
exit-address-family
address-family vpnv4
neighbor 3.3.3.3 send-community extended
neighbor 3.3.3.3 next-hop-self
neighbor 5.5.5.5 send-community extended
neighbor 5.5.5.5 next-hop-self
exit-address-family
address-family ipv4 vrf BLACK
neighbor 12.12.12.1 activate
no synchronization
Between pe there is only vpnv4 no ipv4,
Also next-hop-self is also no need in vpnv4.
Double check
vrf route target import/export.
5 Replies 5
Double check
yes,,,,, there is import cmd missing on other PE,, thanks for your help......
another issue......
R2 cannot ping other customer or PE,,,,but other customers can ping R2 and it's customer R9..
R2#sh ip route vrf BLACK
Routing Table: BLACK
1.0.0.0/32 is subnetted, 1 subnets
B 1.1.1.1 [200/1] via 3.3.3.3, 00:08:49
172.13.0.0/24 is subnetted, 1 subnets
B 172.13.13.0 [200/0] via 3.3.3.3, 00:08:49
172.57.0.0/24 is subnetted, 1 subnets
B 172.57.57.0 [200/0] via 5.5.5.5, 00:08:49
7.0.0.0/32 is subnetted, 1 subnets
B 7.7.7.7 [200/156160] via 5.5.5.5, 00:08:49
9.0.0.0/32 is subnetted, 1 subnets
B 9.9.9.9 [20/0] via 12.12.12.1, 00:08:51
12.0.0.0/24 is subnetted, 1 subnets
C 12.12.12.0 is directly connected, FastEthernet2/1
Any suggestion.
solved redistributed cmd missed...Thanks
redistribute connected
You Are So So Welcome
