10-11-2022 07:23 PM
Can a VLAN be a member of two VRFs on 7010? if so, why would be set up to be on two different VRF?
Solved! Go to Solution.
10-12-2022 12:14 AM
Hello
no a single vlan cannot be in different vrfs
10-12-2022 12:08 AM - edited 10-12-2022 03:25 AM
You can have as many as VLAN in the same VRF (unless mentioned limitations) - if that is the requirement.
Note : VLAN I take Layer 3 SVI , so one SVI can only be in 1 VRF.
10-12-2022 12:14 AM
Hello
