vrf
eng_adel273
I attach GnS3 files & configuration for vrf for two customer
MY problem
- on PE1  ,  I can't execute          ping vrf customer_1 10.0.2.9
- on PE2  ,  I can't execute         ping vrf customer_1 10.0.1.9
27 Replies 27
eng_adel273
I can't attached rar files for GNS3 files
Julio E. Moisa
If im not wrong you will not able to ping these remote networks from the PE because they are part of the CE and the PE routes are not included on the CE's routing table. You can test from CE to CE. Basically you cannot ping the ISP network segments, the traffic between CE is passing through the VPNs creates by the PE's.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
also i can't ping from CE to CE
how can i send the GNS3 files to you to check
could you please copy the config on a notepad and attach it here. Is the same like the word file or there is any modification?
Thank you for your support
kind find the lab in GNS3 through this link
https://www.mediafire.com/folder/9fyf7cnfhe3ni/lab3
Thank you please let me take a look.
Can you post a brief schematic drawing how your 5  routers are connected to each other ?
Each router has loopback 1 from 100.0.0.1 to 100.0.0.6.
I created router ospf 1 and advertise each interface of the routers
what I mean was: what connects to what ? E.g.:
R1 --> R2 --> R3
etc.
I cannot open the GNS3 file you posted since you are using a 12.3 image.
Please check attach word file contains configuration for all routers
sorry, just saw the screenshot you posted in an earlier reply...
As you are using OSPF for the VRF, I suggest to include the command:
router ospf 101 vrf customer_1
capability vrf-lite
router ospf 102 vrf customer_2
capability vrf-lite
Also when you are redistributing into a AF with VRF you can remove the vrf from the routing protocol
redistribute ospf 102 vrf customer_2
Also verify if all the ISP routers are running LDP protocol with show mpls ldp neighbor, if you are using the loopback to create the LDP sessions, check if they are configured with /32
An useful command to verify if you are receiving routes from the BGP VPN is:
show bgp vpnv4 unicast summary all
