Vrf
SajeshB
Need help to understand route between Vlan and Vrf configured vlan
We have 2 L3  vlan created on core switch.
Int vlan 26
Ip add 10.18.71.1
Ip ospf 100 area 0
Int vlan 413
Ip vrf forwarding Red
Ip add 163.122.136.94
Exit
Ip vrf red
Rd 6453:Red
Route target export 6453:Red
Router bgp 6453
Address-family ipv4 vrf red
Redistribute connected
Redistribute static
Exit-address-family
Ip route vrf red 0.0.0.0 0.0.0.0 163.122.136.91
Now i have first firewall connected to vlan 26 and all the traffic from firewall is getting nat to vlan 26 Ip.
And from vlan 26 the traffic is flowing to vlan 413 and going to second firewall as vlan 413 is in vrf and default route is pointed toward second firewall Ip
How the traffic is flowing from vlan 26 to vlan 413 as vlan 413 is in vrf ??
Do i need to check anything in Bgp configuration.
you are right the two firewalls are not connected.
In this case route leakage should be configured between VRF and global routing table using static routes.
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello @SajeshB ,
via the two external firewall devices according to your description.
Please note that playing with route targets in MP BGP is a good way to create communication between two different VRFs, but it does not apply to the global routing table GRT because they miss the route target attribute.
Even if you had two different VRFs you should not try to import / export using route targets because you will risk to bypass the external firewalls.
Hope to help
Giuseppe
Thanks for the reply.
Can u pls see the attach simple network digram both the firewall are not connected.
Hope to help
Giuseppe
Spoiler
Thankyou so much i was also searching the same.
