vss- requirements
Can i use a 6504 and 6510 with sup-720 and 6510 with bland 8 and 9 having link cards ws-f6700. Just wondering do the IOS versions needs to be matched as well. My point is two physical chassis does not need to be identical in the type of modules installed or even type of chassis.
Veera
2 Accepted Solutions
Jon Marshall
From the VSS Q&A -
Q. How many Cisco Catalyst 6500 Series Switches can be part of a VSS?
A. The VSS1440 will allow up to two physical Cisco Catalyst 6500 Series Switches to operate as a VSS. The two physical chassis does not need to be identical in the type of modules installed or even type of chassis. For example, a WS-C6503-E chassis can be combined with a WS-C6513 chassis to form a VS
full link -
http://www.cisco.com/en/US/customer/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b.html
you should however run the same IOS version/feature set on both switches.
Jon
For VSS, you have to use Sup-720-VS.  You cannot use Sup-720.
You also have to use the same exact IOS for both devices.
Reza
Jon Marshall
From the VSS Q&A -
full link -
Jon
Thanks Jon
Reza
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Likely buried somewhere in Jon's link, but you need 10 gig for the link(s) between the two 6500s and you can not use a 6704 line card (for the "special" cross link).
