12-17-2009 07:02 AM - edited 03-04-2019 07:00 AM
I am currently running an E1 from a branch office to our HQ using a VWIC2-2MFT-T1/E1 card at one end and a VWIC2-1MFT-T1/E1 at the other. I am considering upgrading to 4Mb, can these cards handle this data rate and if so what is their maximum data rate?
Graeme
12-17-2009 07:16 AM
E1 is 2 mbps - fixed.
If you upgrade to 4 mbps using E1, the SP will provide a second circuit and you will need 2 interfaces more.
12-17-2009 07:17 AM
Hello Graeme,
E1 is limited to 32 timeslots 64 kbps each, it can be used unframed or framed.
There are other serial interfaces that can have an higher bit rate but not if they are based on E1 standard
see
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
you should deploy two E1 links with multilink PPP for example if this is your hardware.
Hope to help
Giuseppe
12-17-2009 07:24 AM
Thanks for the quick responses, i'll have to add on the cost of another card
12-17-2009 07:33 AM
You are welcome, please remember to rate useful posts clicking on the stars below.
