Community Helping Community
1490
Beginner
VWIC3-1MFT-G703 - config for unframed G703 / local crossover cable for setup?
From our carrier we get a 2MBit line specified as "unframed G703". This line should be connected to two 2900-Routers (IOS 15.1) each equipped with a VWIC3-1MFT-G703-card.
Being absolutely new to G703 I'm looking for a basic config so we can use that line just for pure data - no split data/voice and/or any other fancy things - just a vanilla 2Mbit pipe of data.
Since in the end these two routers will be several hundreds of kilometers apart I'd like to make sure, that esp. the WAN link works. Given the fact that the G703-interface of the two routers has a RJ45-plug: can I simply connect the two routers back2back via an Ethernet crossover-cable to "emulate" the WAN-connection?
Thanks much in advance for your help,
-ewald
1 ACCEPTED SOLUTION
Hall of Fame Master
Not a secret really, 1 and 2 to 4 and 5.
Please remember to rate useful posts clicking on the stars below.
5 REPLIES 5
Hall of Fame Master
This is often asked and you would have found searching before asking.
Anyway, Yes, you can use a T1/E1  crossed cable (not an ethernet cable) to make a local connection.
You will need to supply clock on one side.
Beginner
Oops, so no way of using a normal patch-cable?
Do you know where I can find the pinouts of a crossed E1-cable?
-ewald
Hall of Fame Master
Beginner
Hi Paolo,
thanks alot - with all questions answered I'll proceed going out configuring a cable...
-ewald
Beginner
1 and 2, 4 and 5 pairs are
1 and 2, 4 and 5 pairs are the same on an ethernet straight through. Yes, you can use a standard ethernet cable to connect VWIC3.
Content for Community-Ad
FusionCharts will render here
