12-11-2015 03:43 AM - edited 03-05-2019 02:55 AM
Anybody know if I use VWIC3-1MFT-T1/E1 for wan data configuration only, Does it require PVDM3 on the router?
Tinnakorn
Solved! Go to Solution.
12-11-2015 06:39 AM
hi,
no, you don't need a PVDM module on the router.
you use a PVDM if you're running an ISDN/channelized E1 or T1 on the router.
12-11-2015 05:48 AM
If you router supports VWIC3-1MFT-T1/E1, you do not need any extra module for data.
Just you need to configure controller E1 or T1 and corresponding serial interfaces.
Hope it helps,
Masoud
12-11-2015 06:39 AM
hi,
