vWLC support on ISR 4321/4331
I have a customer who has ISR 4331 and 4321 on branch sites. There is no UCS-E modules but we do have 200GB SSD storage and 8/16GB of RAM. In this configuration, is it possible and supported to run a low scale vWLC as a service container ?
Vincent
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
Re: vWLC support on ISR 4321/4331
Sorry yes that's the architecture behind Mobility Express.
If you're looking to upgrade the APs, you might want to take a look at the 18/28/3800 APs with Mobility Express. You don't need an additional WLC then. The WLC2504 is also a really good option that isn't too expensive. Finally, if they have an ISR4K you could use a NIM UCS-E with vWLC (UCS-EN140N-M2/K9). Least expensive would probably be the Mobility Express route followed by the 2504 and finally the UCS-E although I'm not certain on pricing.
4 REPLIES 4
Beginner
I am interested in this also...
CCIE# 6771
Technically this is possible. However the WLC product team has decided not to productize a KVM version of vWLC running on an ISR. That could change in the future with either a hosted KVM WLC (vWLC) or WLC functionality native on the ISR4K. Because we share a code base with the Catalyst series of switches, both of these are possibilities.
Beginner
Thank you, is the eWLC you are referring to the same as mobility express?
I google 'cisco eWLC' and the only results from Cisco are a couple bug reports...
just looking to replace a customers ISR/NM-WLC6/1242G solution without breaking the bank...
CCIE# 6771
Content for Community-Ad
August's Community Spotlight Awards
