VxLAN with 2 data centers
I'm exploring the new data center with this VxLAN lab, just only one l2 domain with BGP EVPN. However, I have confused with the physical connection. I suppose the Leaf-1 is on the new DC, how both two DC connect? Which solution is the easiest way?
Thank you very much.
5 Replies 5
Borair
hello
in case you want to extend the fabric between two DC or more you should use  OTV or EVPN Multisite in order th do this
OTV is only supported by a limited number of devices, ie the N7K and ASR1K. In addition for the N7K, OTV is only supported by the more expensive F3 modules?
in this case you can use EVPN Multisite to do this and its support with the same fabric device NX-9K
Ha ha, however, I see Cisco said OTV is the best. And the lab looks easier https://ithitman.blogspot.com/2018/05/configuring-otv-otv-configuration-and.html. Just rent MPLS L2VPN or dark fiber for 2.2.2.0/30, but for VxLAN lab I can't illustrate how physical cross site will connect.
OTV is limited with only NX-7K but vxlan evpn can run with NX-9K and the thing that there is no multisite with EVPN its not true because you can run EVPN multiste replace of OTV for create DCI and for your question about how you can connect multiple DC its can done with 4 design one of them by using super spine topology
