178
BartV1982
Beginner
waas 4.1.1 load-balancingf between WAEs
can anybody help to enable load-balancing between different WAEs on a site
i added a drawing to this topic
we have 3 WAEs on the LAN and we would like to spread the load on all 3.
At this moment this is not even
Please help
thank you in advance
2 REPLIES 2
htarra
Enthusiast
WCCP automatically distributes load among available Cisco WAEs, providing linear scalability of performance. In this way, all WAEs are used simultaneously, thereby improving overall capacity for application acceleration and WAN optimization. Redirection is performed statefully based on a load-balancing algorithm that helps ensure that a flow is always redirected to the same WAE every time to facilitate maximum performance and optimization
Mohamed Sobair
Rising star
what if I had to use PBR instead of WCCP?? does loadbalancing takes effect in this case? and How WCCP determines the loadbalancing Scheme? Pls provide us with some technical documentation for WAAS describing the Loadbalancing Scheme among multiple Wide Area engines.
Mohamed
