07-26-2018 01:24 AM
Hello, I am currently labbing/ planning our design on how to dynamically route between our core sites into our ISP WAN (WAN only no internet).
We have a couple of requirements:
We want to redistribute certain subnets from our internal OSPF areas at each core site into BGP and vice-versa, however we also want to tag the ISP to tag the default routes for each site for failover. (Site A is primary for geographically closer sites etc).
Could someone help with the design here? Not done much BGP/OSPF other than troubleshooting.
Design on our Cores which will connect directly into the ISP router (Via Layer 2 connections).
router bgp xxxx0 no synchronization bgp router-id xxx.xxx.xxx bgp log-neighbor-changes network 172.xxx.xxx.xxx network 172.xxx.xxx.xxx mask 255.255.255.252 redistribute ospf 100 route-map redistribute-OSPF-to-BGP default-information originate neighbor 172.xxx.xxx.xxx remote-as xxxx1 router OSPF 100 redistribute bgp 65533 route-map redistribute-BGP-to-OSPF metric-type 2
Current ASR Config.
ASR-01 & ASR-02 router bgp 65501 bgp router-id 192.168.99.200 bgp log-neighbor-changes redistribute ospf 1 route-map SNEY->YORK neighbor 192.168.195.249 remote-as 65502 neighbor 192.168.195.250 remote-as 65502 router ospf 1 router-id 192.168.99.200 auto-cost reference-bandwidth 10000 area 0 authentication message-digest timers throttle spf 10 100 5000 timers throttle lsa 10 100 5000 timers lsa arrival 80 redistribute bgp 65501 metric-type 1 subnets passive-interface default no passive-interface GigabitEthernet0/0/0 no passive-interface GigabitEthernet0/0/1 no passive-interface Port-channel10 ASR-03 & ASR-04 router bgp 65502 bgp router-id 192.168.6.55 bgp log-neighbor-changes redistribute ospf 100 route-map SITEA->SiteB neighbor 192.168.195.251 remote-as 65501 neighbor 192.168.195.252 remote-as 65501 Router ospf 100 router-id 192.168.6.55 redistribute static metric-type 1 subnets redistribute bgp 65502 metric-type 1 subnets passive-interface default no passive-interface GigabitEthernet0/0/0 no passive-interface GigabitEthernet0/0/1 no passive-interface Port-channel10 network 192.168.3.0 0.0.0.3 area 699 network 192.168.3.8 0.0.0.3 area 699 network 192.168.6.55 0.0.0.0 area 699 network 192.168.195.56 0.0.0.7 area 699
Cheers
07-26-2018 02:06 AM
what is your specific question about your design, that is, what part is not working as per your requirements ?
07-26-2018 03:15 AM
