wan connection type
fouad-zeyad1
hi,
i need to know all things about WAN connection
can i use ADSL? how many distance it provide?
i need WAN technology that support high distance and low price
thanks
6 Replies 6
Philip D'Ath
If price and distance are the primary concerns then you should use Internet tails and Cisco DMVPN technology (part of iWAN) to build a WAN emulation that runs over the Internet.
http://www.cisco.com/c/en/us/products/security/dynamic-multipoint-vpn-dmvpn/index.html
http://www.cisco.com/c/en/us/solutions/enterprise-networks/intelligent-wan/index.html
Cheap, and it doesn't care about distance.
i want to improve dsl network, how?
can i use VDSL or SHDSL to 10km
which devices should i use
VDSL is higher speed.  SHDSL is symmetric but usually slower.
You need to check with a service provider first what services are available at the IP address.
which devices provide adsl, vdsl and shdsl
are cisco 1921 provide it?
There really isn't enough information to make product recommendations. A Cisco 897VA can do ADSL, VDSL and has an SFP+Copper WAN port. The Cisco 1921 is modular, so you can put what you want into it.
You should speak to a local Cisco partner.
Cisco Partner Locator
