WAN link load balancing
Cybervex3
We are adding a second ISP and I am looking for a sufficient router to provide load balancing between the two ISPs.  I am also kicking around the idea of forgetting the router and just making the T1 a backup route if the WiMax goes down, using only the ASA5510.
Currently have:
T1(ISP Router) <-> ASA5510 <-> LAN
Looking to have:
T1 (ISP Router)       <->
                                          Router ?    <->     ASA 5510  <->  LAN
WiMax(ISP Router) <->
Thanks in advance for any suggestions
Jay
7 Replies 7
Edison Ortiz
Are you looking into internet load-balancing with 2 different ISPs?
Did they give you an public IP address block? I'm sure the other ISP will give you another public IP address block.
Are you using BGP?
Edison
Are you using BGP?
Edison
1. Yes. Each link will be from a different ISP.
2. Each ISP will be supplying a block of IPs.
3. We currently only have the single T1 link using the ISP owned router.  The handoff to us is ethernet to our ASA5510.
I would prefer to use some type of Load Balance/Load Share to not have the T1 sitting there doing nothing.
Talha Ansari
If this would be your topology
T1 (ISP Router)       <->
Then I believe you can have load-sharing but not load-balancing where you can define a group of users from ur lan subnet to take one path and the rest of the users to take another, and in case of failure of one path, all users take the path that is up and working using some route-maps or ipslas.. but I dont think you can have something as per packet basis.
If both the ISPs are same and if they provide multilink or bvi then in that case you may change the load-sharing to per-packet basis. I dont think SPs provide this luxury..
sameer.mulgund
considering your current setup, you can do load balancing with redundancy (protecting data traffic during failure) using GLBP (Gateway load balncing protocol). Gateway Load Balancing Protocol (GLBP) protects data traffic from a failed router or circuit, like Hot Standby Router Protocol (HSRP) and Virtual Router Redundancy Protocol (VRRP), while allowing packet load sharing between a group of redundant routers.
Sameer
Sameer
Which router would you suggest to pull this off?
As far as I know, the 6500 series MLS is the only device that supports GLBP according to the CCNP switch book documentation.
hello,
if we are playing on the BGP metrics, can i know the destination learnt by both the ISP, please find the attachment and i hope that is the scenario you have in that case i suggest you to go for 2821 router and 2 port ethernet card if the ISP are ready to give the link on ethernet handoff
please find the 2821 router configuration
In this scenario, load balancing is not an option in a multihomed environment, so you can only do load sharing.
You cannot do load balancing because BGP selects only a single best path to a destination among the BGP routes that are
learned from the different ASs
interface gi0/0
ip address x.x.x.x 255.255.255.252
no ip route-cache
interface gi0/1
no ip route-cache
router bgp x
neighbor x.x.x.x remote-as 10
neighbor x.x.x.x route-map over-T1 in
neighbor x.x.x.x remote-as 20
neighbor x.x.x.x route-map over-wimax in
auto-summary
route-map over-T1 permit 10
match ip address 1
set weight 100
route-map over-T1 permit 20
match ip address 2
route-map over-wimax permit 10
match ip address 2
set weight 100
route-map over-wimax permit 20
match ip address 1
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 permit 20.20.20.0 0.0.0.255
in this scenario if you have learned 10 n/w over ISP T1 router and traffic destined to this from you LAN will also go on the same link,please let me know your destination n/w so that we can play on that
