WAN load balancing between 2 routers?
j_friedrich
Hi guys,
     Just a general question how well this might work....
I would like to decrease the cpu load on our edge router.  Can we load balance a single WAN link among 2 routers to effectively reduce the cpu load on the main edge router?
Thanks for everyone's input!
Jason
Reza Sharifi
If your CPU on the edge router is high, it may not necessarily be the WAN circuit.  You would need to look at the different features you are running on your router and figure out which one is causing the high CPU.  It also depended on the size of the circuit and also the type of router you are using.  Most routers can handle one WAN circuit with no issues.  Usually, one circuit can be only terminated in one router and not multiples.
Hi Reza,
     Here is a 'show processes cpu sorted' dump for you.  As you can see, there is nothing there that shows anything abnormal.  We are running a 100/5 connection that is usually fully utilized.
CPU utilization for five seconds: 56%/54%; one minute: 55%; five minutes: 54%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
217       76392  1357364375          0  0.31%  0.36%  0.35%   0 HQF Output Shape
110        8640   692396143          0  0.23%  0.22%  0.23%   0 Ethernet Msec Ti
159          24         132        181  0.15%  0.01%  0.00% 132 Virtual Exec
109         864    34585551          0  0.07%  0.00%  0.00%   0 Ethernet Timer C
289       24296    11014570          2  0.07%  0.12%  0.14%   0 IP NAT Ager
151      595780     2644506        225  0.07%  0.01%  0.00%   0 IP Input
105        8724    10884370          0  0.07%  0.01%  0.00%   0 BPSM stat Proces
  31     5614964    84851804         66  0.07%  0.13%  0.15%   0 ARP Input
   8           0           2          0  0.00%  0.00%  0.00%   0 Timers
   9           8        2596          3  0.00%  0.00%  0.00%   0 WATCH_AFS
  11           0           1          0  0.00%  0.00%  0.00%   0 Image License br
  10           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  13     4366024     5437883        802  0.00%  0.04%  0.04%   0 Environmental mo
   7           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  15          52       90645          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  16           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  12     3693320       90645      40744  0.00%  0.05%  0.05%   0 Licensing Auto U
   6       22344       91054        245  0.00%  0.00%  0.00%   0 Pool Manager
  19         900     5314623          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  20           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  14        3948     1087734          3  0.00%  0.00%  0.00%   0 IPC Event Notifi
   5     4918556      829652       5928  0.00%  0.08%  0.06%   0 Check heaps
  24           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  25          28      544239          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  26          44     1088468          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  27           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  28           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  17           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  18         824     5314623          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  22           8      310993          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  33           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  34           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  35           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  36           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  37           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  38           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  39           0           4          0  0.00%  0.00%  0.00%   0 Entity MIB API
  40        2144          29      73931  0.00%  0.00%  0.00%   0 PrstVbl
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  42           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  30           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  44           4           1       4000  0.00%  0.00%  0.00%   0 RF SCTPthread
  45           0           1          0  0.00%  0.00%  0.00%   0 CHKPT RG SCTPthr
  46        1164       47120         24  0.00%  0.00%  0.00%   0 ARP Snoop
  47        5096     5442342          0  0.00%  0.00%  0.00%   0 GraphIt
  48           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  49           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  50           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  51           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  52       13348      562160         23  0.00%  0.00%  0.00%   0 Net Background
  53           0           3          0  0.00%  0.00%  0.00%   0 IDB Work
  54         236      652641          0  0.00%  0.00%  0.00%   0 Logger
  32        7000     5673456          1  0.00%  0.00%  0.00%   0 ARP Background
   4           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  57           4           4       1000  0.00%  0.00%  0.00%   0 IF-MGR control p
  41           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  59           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  60           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  61           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
  62           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
  63           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  64           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  65           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  66           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  67           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  68           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  69           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  70           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  71           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
   3           4           1       4000  0.00%  0.00%  0.00%   0 LICENSE AGENT
  73           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-HA
   2        5668     1088470          5  0.00%  0.03%  0.02%   0 Load Meter
  75           0           7          0  0.00%  0.00%  0.00%   0 RF Master Main T
  43           0           2          0  0.00%  0.00%  0.00%   0 SMART
  77         828       55415         14  0.00%  0.00%  0.00%   0 Net Input
  78        1828     1088534          1  0.00%  0.00%  0.00%   0 Compute load avg
  79      419048      183207       2287  0.00%  0.00%  0.00%   0 Per-minute Jobs
  55        2212     5437884          0  0.00%  0.00%  0.00%   0 TTY Background
  81           0           3          0  0.00%  0.00%  0.00%   0 AggMgr Process
  82           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  83           0       23058          0  0.00%  0.00%  0.00%   0 Transport Port A
  84       34576     1125817         30  0.00%  0.00%  0.00%   0 HC Counter Timer
  85       11448      362568         31  0.00%  0.00%  0.00%   0 SM Monitor
  86           0           2          0  0.00%  0.00%  0.00%   0 SM Installer
  87           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  88           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  89           0           2          0  0.00%  0.00%  0.00%   0 ESWPPM
  90           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  91       12796         628      20375  0.00%  0.00%  0.00%   0 DXMRVL
  92           0           1          0  0.00%  0.00%  0.00%   0 esw_mrvl mat que
  93      313824     5488955         57  0.00%  0.00%  0.00%   0 ehwic_eswge Proc
  94         132     5442176          0  0.00%  0.00%  0.00%   0 Console redirect
  95           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_DELA
  96           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_SCTP
  97           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED Identity
  98        9384      408738         22  0.00%  0.00%  0.00%   0 EEM ED ND
  99         668     5433146          0  0.00%  0.00%  0.00%   0 Dynamic DNS Upda
100           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
101          28        1116         25  0.00%  0.00%  0.00%   0 IGMP Snooping Re
102         116      181289          0  0.00%  0.00%  0.00%   0 Call Management
103           4           2       2000  0.00%  0.00%  0.00%   0 USB Startup
104           0           1          0  0.00%  0.00%  0.00%   0 CF_INTERDEV_SCTP
  58           4         540          7  0.00%  0.00%  0.00%   0 IF-MGR event pro
106        1764         264       6681  0.00%  0.00%  0.00%   0 i2c sm_exchange
107      115728      162104        713  0.00%  0.00%  0.00%   0 i2c console redi
108           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  56           0           6          0  0.00%  0.00%  0.00%   0 RF Slave Main Th
  72           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
111           8         593         13  0.00%  0.00%  0.00%   0 Auth Manager
112           0           1          0  0.00%  0.00%  0.00%   0 AUTH POLICY Fram
113           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
114           0           1          0  0.00%  0.00%  0.00%   0 802.1x Webauth F
115           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
116           0           2          0  0.00%  0.00%  0.00%   0 CMD HANDLER
117           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
118           0           1          0  0.00%  0.00%  0.00%   0 SFF8472
119         668     5437886          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
120           0           2          0  0.00%  0.00%  0.00%   0 call_home_les_oi
121           0           1          0  0.00%  0.00%  0.00%   0 SMI Director DB
122           0           1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
123           0           1          0  0.00%  0.00%  0.00%   0 SMI Backup Proce
124           0           2          0  0.00%  0.00%  0.00%   0 RG Faults Timer
125           0           2          0  0.00%  0.00%  0.00%   0 RG Protocol Time
126           0           2          0  0.00%  0.00%  0.00%   0 RG Transport Tim
127           0           1          0  0.00%  0.00%  0.00%   0 RG VP
128           0           2          0  0.00%  0.00%  0.00%   0 RG AR
129           0           3          0  0.00%  0.00%  0.00%   0 CTS CORE
130           8         201         39  0.00%  0.00%  0.00%   0 SXP CORE
131           4       45354          0  0.00%  0.00%  0.00%   0 DHCP Snooping
132           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
133           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
134           0           2          0  0.00%  0.00%  0.00%   0 AAA Server
135           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
136           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
137           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
138       32196     1495544         21  0.00%  0.00%  0.00%   0 CDP Protocol
139           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
140           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
141           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
142           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
  74          12       47741          0  0.00%  0.00%  0.00%   0 TDM Management
144           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
145           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
146           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
  76           0           2          0  0.00%  0.00%  0.00%   0 RF Master Status
148           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
149          44         401        109  0.00%  0.00%  0.00%   0 IP ARP Adjacency
150           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
  80        8312     5442705          1  0.00%  0.01%  0.00%   0 Per-Second Jobs
152           0          99          0  0.00%  0.00%  0.00%   0 ICMP event handl
153           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
154          12        9031          1  0.00%  0.00%  0.00%   0 MOP Protocols
155           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
156           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
157           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
158           0           1          0  0.00%  0.00%  0.00%   0 HQF TUNNEL
   1         932       10257         90  0.00%  0.00%  0.00%   0 Chunk Manager
160           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
161           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
162           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
163        5160    21259209          0  0.00%  0.00%  0.00%   0 SSS Feature Time
164      262724     8318203         31  0.00%  0.02%  0.00%   0 Spanning Tree
165           0           2          0  0.00%  0.00%  0.00%   0 SSM connection m
166           0           1          0  0.00%  0.00%  0.00%   0 WAAS Process
167           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
168          76       90645          0  0.00%  0.00%  0.00%   0 FRR Background P
169        5976      108752         54  0.00%  0.00%  0.00%   0 CEF background p
170           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
171           0           1          0  0.00%  0.00%  0.00%   0 IPC UDP Input
172       15304     7633442          2  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
173           0          28          0  0.00%  0.00%  0.00%   0 ADJ background
174           0          26          0  0.00%  0.00%  0.00%   0 Collection proce
175           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
176           0           1          0  0.00%  0.00%  0.00%   0 Critical Auth
177           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
178           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
179           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
180          48         306        156  0.00%  0.00%  0.00%   0 L2MM
181           0           1          0  0.00%  0.00%  0.00%   0 MRD
182          36        1114         32  0.00%  0.00%  0.00%   0 IGMPSN
183           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
184           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
185           0           2          0  0.00%  0.00%  0.00%   0 RG Media Timer
186           0           1          0  0.00%  0.00%  0.00%   0 RG If-Mgr Timer
187           0           2          0  0.00%  0.00%  0.00%   0 Routing Topology
188           8         334         23  0.00%  0.00%  0.00%   0 IP RIB Update
189         200       91121          2  0.00%  0.00%  0.00%   0 IP Background
190           0         859          0  0.00%  0.00%  0.00%   0 IP Connected Rou
191           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
192         436       90660          4  0.00%  0.00%  0.00%   0 Call Home Timer
193           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
194           0           1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Event H
196           0           3          0  0.00%  0.00%  0.00%   0 Service Routing
197           8         701         11  0.00%  0.00%  0.00%   0 SR CapMan Proces
198           0           1          0  0.00%  0.00%  0.00%   0 SNMP Timers
199           0          29          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
200         428       39009         10  0.00%  0.00%  0.00%   0 TCP Timer
201        1216       24160         50  0.00%  0.00%  0.00%   0 TCP Protocols
202          80       18569          4  0.00%  0.00%  0.00%   0 HTTP CORE
203           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
204           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
205           0           1          0  0.00%  0.00%  0.00%   0 COPS
206           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
207         160        1698         94  0.00%  0.00%  0.00%   0 ADJ resolve proc
208           0           3          0  0.00%  0.00%  0.00%   0 MFIB Master back
209           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
210           0           1          0  0.00%  0.00%  0.00%   0 RARP Input
211           0         185          0  0.00%  0.00%  0.00%   0 static
212           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
213           0           1          0  0.00%  0.00%  0.00%   0 LAPB Process
214           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
215           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
216        4876      543872          8  0.00%  0.00%  0.00%   0 QoS stats proces
143           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
218           0           2          0  0.00%  0.00%  0.00%   0 HQF Input Shaper
219         708     5439044          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
220           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
222           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
223           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
224           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
225           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
226           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
227           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
228           0           2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
229           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
230           8        4536          1  0.00%  0.00%  0.00%   0 NIST rng proc
231           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
232           0           2          0  0.00%  0.00%  0.00%   0 CSDB Timer proce
233           0           2          0  0.00%  0.00%  0.00%   0 crypto engine pr
234          48        6051          7  0.00%  0.00%  0.00%   0 Crypto CA
235           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
236           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
237        1144         102      11215  0.00%  0.00%  0.00%   0 crypto sw pk pro
238           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
239           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
240        1072     3917219          0  0.00%  0.00%  0.00%   0 PM Callback
241          40      435390          0  0.00%  0.00%  0.00%   0 dhcp snooping sw
243           4          85         47  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
244           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
245           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Routing
246       13976      367847         37  0.00%  0.00%  0.00%   0 EEM ED Syslog
247           0           4          0  0.00%  0.00%  0.00%   0 EEM ED NHRP
248           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Track
249           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Resource
250         160      543865          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
251           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
252           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
253           0           1          0  0.00%  0.00%  0.00%   0 WAN Optimization
255         104           2      52000  0.00%  0.00%  0.00%   0 VLAN Manager
257           0           4          0  0.00%  0.00%  0.00%   0 RBM CORE
258           4           3       1333  0.00%  0.00%  0.00%   0 CTS credentials
259          16         243         65  0.00%  0.00%  0.00%   0 EEM Server
260           4          33        121  0.00%  0.00%  0.00%   0 Call Home proces
261           4           3       1333  0.00%  0.00%  0.00%   0 EEM Policy Direc
262           0        1514          0  0.00%  0.00%  0.00%   0 SSH Event handle
263           0           4          0  0.00%  0.00%  0.00%   0 EEM ED CLI
264           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Counter
265           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Interface
266           0           4          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
267           0           4          0  0.00%  0.00%  0.00%   0 EEM ED None
268           0           4          0  0.00%  0.00%  0.00%   0 EEM ED OIR
269           0           4          0  0.00%  0.00%  0.00%   0 EEM ED RF
270           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
271           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
272           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
273          32       90803          0  0.00%  0.00%  0.00%   0 EEM ED Timer
274           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Test
275           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Config
276           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Env
277         744        5511        135  0.00%  0.00%  0.00%   0 DHCPD Receive
278           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED Nf
279          32        1025         31  0.00%  0.00%  0.00%   0 Syslog
280           0           4          0  0.00%  0.00%  0.00%   0 EEM ED RPC
281           0           1          0  0.00%  0.00%  0.00%   0 tHUB
282           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
283           4           1       4000  0.00%  0.00%  0.00%   0 Async write proc
284           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
285           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
286           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
287         172       90645          1  0.00%  0.00%  0.00%   0 DFS flush period
288          12         403         29  0.00%  0.00%  0.00%   0 EEM Helper Threa
147       37996   169882340          0  0.00%  0.05%  0.05%   0 IPAM Manager
290           0           1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
291        6900      320570         21  0.00%  0.01%  0.00%   0 IP VFR proc
292         628       11217         55  0.00%  0.00%  0.00%   0 l4f mgt task
293           0           1          0  0.00%  0.00%  0.00%   0 L4F OOB Process
294        1260     5314646          0  0.00%  0.00%  0.00%   0 CFT Timer Proces
295         744     5437987          0  0.00%  0.00%  0.00%   0 DHCP Client
297           4       45402          0  0.00%  0.00%  0.00%   0 DHCPD Timer
298          76       90644          0  0.00%  0.00%  0.00%   0 DHCPD Database
Thanks.
vmiller
Level 7
Level 7
The only pure router i know of that supports something like you ask is the 1941 wireless carriers.
do you have things like NAT, or long access lists, policy based routing running ?
     The only things we have running is NAT and an acl to drop fragments...that's it.
Thanks.
