WAN LOAD SHARING???
madathilsiva
Hi all,
we have a network as mentioned below
1. Router 1841- IOS 12.4 (25)
There are two WAN connection we have . One is 2Mbps and another one is 4Mbps. And one Internal network  ie 10.0.0.0 /24
In this  10.0.0.x and 10.0.0.y are using for Video confference. Remaining all are for users .
I want these two to communicate always with my 2 mbps line and if they are not in use i need total of  6mbps (4 + 2 mbps ) connection for my useres Cisco 1841 Router . How can i achive this ? Please help .....
Sivapraksh.M
john.mcmanus
Look into glbp gateway load balancing protocol. This can be used for outbound balancing. I use the term balancing loosely. For inbound depends on the wan protocol
Sorry assumed two routers.
can you give me the destination ips , i.e when i take a example 10.10.10.1/24 and 10.10.10.2/24 are the ips on your LAN that are trying to communicate to some ip for video communication and other ips in the SUBNET that the users are trying to access. it becomes very easy to do this when you have the destination ips
