WAN PIM Sparse-Mode
specialed351
I am trying to route multicast packets over a WAN. through a 6509 to a 3750. Both routing. the 6509 is routing dense mode to the local lan and sparse mode to the WAN. (please see the mroute output for the 6509 below)
the source for the group is directly connected to the 6509.
(*, 239.0.1.1), 01:03:46/stopped, RP 10.1.255.1, flags: DC
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Vlan22, Forward/Dense, 01:03:46/00:00:00
Vlan24, Forward/Dense, 01:03:46/00:00:00
(10.1.2.19, 239.0.1.1), 01:03:46/00:02:56, flags: T
Incoming interface: Vlan2, RPF nbr 0.0.0.0, RPF-MFD
Vlan24, Forward/Dense, 01:03:46/00:00:00, H
Vlan22, Forward/Dense, 01:03:46/00:00:00, H
the 3750 is pulling through sparse mode, but never seems to register with the RP and therefore flow data:
(*, 239.0.1.1), 03:24:45/00:02:56, RP 10.1.255.1, flags: SJC
Vlan521, Forward/Sparse, 01:59:11/00:02:56
also note the "sh ip mroute count" output and how the packets are all in "Other".
Group: 239.0.1.1, Source count: 0, Packets forwarded: 0, Packets received: 417321
RP-tree: Forwarding: 0/0/0/0, Other: 417321/0/417321
Can any one help?
Ed
ivillegas
Level 6
Level 6
Did you enable multicast routing in the 3750?
