WAN router CPU @ 80% causing problems - please assist
Steve Coady
My WAN router CPU had massive spike
CPU utilization for five seconds: 80%/68%; one minute: 60%; five minutes: 62%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  87    33845184-225308168          0  0.81%  0.73%  0.76%   0 IP SLA Mon Event
  39   369005648 176573942       2089  0.40%  0.39%  0.40%   0 Per-Second Jobs
   5   216170736  21223865      10185  0.40%  0.14%  0.08%   0 Check heaps
 208        4340       497       8732  0.24%  0.04%  0.09%   0 Exec
 138    190964441078152403         17  0.16%  0.16%  0.16%   0 IP SLA Mon Respo
  81   268436924 663445230        404  0.08%  0.15%  0.19%   0 IP Input
sMc
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Your five second values, show most CPU is interrupt CPU, which usually is due to packet forwarding.  What's the router model and the total transit traffic volume?
Also, your process CPU is a tad high for the 5 second measurement.  Is the spread normally about 12%?  What do you see if you sort the CPU utilization list?
Do you have ACL restrictions on SNMP to allow only your servers?
Do you have CoPP enabled?
5 Replies 5
Joseph W. Doherty
Disclaimer
Posting
Joe
Not sure if 12% diff is nromal
Router model is 3725
3725#sh proc cpu sorted
CPU utilization for five seconds: 64%/63%; one minute: 62%; five minutes: 61%
  39       16436      2304       7133  0.40%  0.38%  0.35%   0 Per-Second Jobs
 214        1180    142426          8  0.24%  0.19%  0.18%   0 IP SLA Mon Respo
  81       43032     22332       1926  0.24%  0.25%  0.24%   0 IP Input
  87        7388      2615       2825  0.16%  0.17%  0.08%  98 SSH Process
 138        3612       267      13528  0.16%  0.05%  0.18%   0 Exec
 122          16      2299          6  0.08%  0.00%  0.00%   0 bsm_xmt_proc
 108         160      3446         46  0.08%  0.01%  0.00%   0 CEF process
 135         192     22832          8  0.08%  0.03%  0.02%   0 RBSCP Background
   8           0        41          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
   6           0         5          0  0.00%  0.00%  0.00%   0 Pool Manager
   7           4         2       2000  0.00%  0.00%  0.00%   0 Timers
   9           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  10          28      2300         12  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  14           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  15           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  11          12      2300          5  0.00%  0.00%  0.00%   0 IPC Deferred Por
  17         512      1012        505  0.00%  0.00%  0.00%   0 ARP Input
  12           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
sMc
Disclaimer
Posting
Ok, assuming it's not, what you're aggregate traffic volume (as about 50 Mbps could max out a 3725).
Joe
Thank you for the response.
We thought it might be the router having issues. it is a 3725 and had not been rebooted in 5 .5 years.
We replaced the router with a newer 3825. The same issue is occurring. Something with
SNMP is spiking the processor to 80-100%
Any ideas on what could be causing that. This is a new development within the last couple days.
sMc
