Wan subinterface on 871
rfairclough
Hi peoples,
Can someone verify if I can give a trunk handoff to a 871 ?
Can the 871 deal with creating dot1q sub interfaces on fa4 ?
This is on a Advanced IP services IOS.
Yes I know it is possible to create VLANs and then use an LAN port but I wish to use 3 VLANs externally/internally.
Cheers.
Yes this is possible.
You need a proper IOS image.
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
spremkumar
Level 9
Level 9
In addition to the other post you need to have Advanced IP Services IOS image in your box to have VLANs configured in your box.
do refer the below link for more info on the same..
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
regds
Hi guys,
Thanks to Iwan & spremkumar for the answers.
Was able to live test & confirm it was all possible.
Thanks.
