Wanted to Load Factory Defaults for 881W - Now Cant Access It
jaesposito
All,
I wanted to load the factory defaults for my 881W so I could get a clean start. Following this Cisco article:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_tech_note09186a00802017a1.shtml
I used the following commands while telnetted in via an ethernet cable to one of the ethernet ports:
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#reload System configuration has been modified. Save? [yes/no]: n Proceed with reload? [confirm]
    Once I hit enter to proceed with the reload, the router power cycled. From that point forward, I never got a link light or connection via my ethernet cable to the router on any of the ethernet ports (0,1,2,3). I can get a link light on WAN FE4, but no DHCP ip address to telnet in.
    I do not have a Cisco USB console cable, which is why I've been trying this via my ethernet cable. Hopefully, I didnt screw up the router.
    Any thoughts on what I can do in order to get back into the 881W?
    Thanks very much,
    James
    cadet alain
    the only way to communicate with the device is via the rollover cable now.
    Alain
