Warranty WS-C3560G-48TS-S Switch
SWKapfenberg1
Dear Ladies and Gentlemen.
We bought a WS-C3560G-48TS-S Switch on the 15th of july 2010.
After a power failure the switch never goes online, only the "SYST"-LED lights but no connection or remote access is possible.
Do you have any ideas how I can get the switch online again?
Is there any chance to repair this switch or is there still a warranty? (normally 5 years after EOSale or?)
Serial Number is SFOC1414Y2V0.
Thanks for your help and best regards.
Martin Weber
Mark Malone
hey do you get any type of console output when connected directly in ?
Cisco hardware equipment is only covered by a 90 day warranty , its support contracts after that , that would entitle you to an RMA replacement for free , there are 3rd party companies that will fix the switch but I would just get another one on ebay , that model goes for a few hundred dollars now will probably cost more to fix than buy
