WCCP issue with virtual-template 1 on ASR 1001
kashalo84
Beginner
Beginner
Hi all
am trying to configure the wccp on virtual template but when i added the follwoing command in virtual-template configuration i get the following error.
LNS-3(config)#inter virtual-template 1
LNS-3(config-if)#ip wccp 80 redirect in
Jan 22 18:48:19.683: %IOSXE_WCCP-4-NOINTF: No Virtual-Template1 interface info for Service Group (1, 80, 0)
-Traceback= 1#f3458ff72c5f00e4e4a20998f488c178  :400000+1271923 :400000+5A11016 :400000+35E7DD5 :400000+35E774F :400000+116B298 :400000+116A99D :400000+1168945 :400000+40255C0 :400000+1197CB0 :400000+11994A1 :400000+1198CF8 :400000+11966DB :400000+1196541 :400000+11961FB :400000+1183858
and then the follwing error always popup
Jan 22 18:48:26.326: %FMANRP_ESS-4-FULLVAI: Session creation failed due to Full Virtual-Access Interfaces not being supported. Check that all applied Virtual-Template and RADIUS features support Virtual-Access sub-interfaces. swidb= 0x7FFDA39236F8, ifnum= 41
any help please
The "%IOSXE_WCCP-4-NOINTF: No Virtual-Template1 interface info for Service Group (1, 80, 0)" notification is due to a cosmetic bug CSCtc01098. No impact or actual issue. I suggest you upgrade to 3.10s or later.
The "%FMANRP_ESS-4-FULLVAI:" is due to a RADIUS attribute "Framed-Compression" that is set to Van-Jacobsen-TCP-IP. This will cause the ASR1K to use Full Virtual Access Interface. Unfortunately this is not supported on the ASR 1000 as is.  For a workaround look at the following guide:
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/scaling.html#wp1124018
HTH,
Michel.
Recognize Your Peers
