webui not graphical user interface
J-Dread
I'm trying to configue web ui on a isr 4331 router.
IOS XE is version is 03.16.06.S, which might be ancient
IOS version is 15.5
I can connect to webui but the page isn't graphical, just a list of cli commands.
Any suggestions.
I bouhgt the router to study for CCNA.
Richard Burts
In studying for CCNA you should recognize that most Cisco IOS routers do most of their configuration using Command Line Interface and their graphical capabilities are quite limited. My advice to you is to learn to use CLI.
Rick
Thank you for your reply.
I am aware "most router Cisco routers do most of their configuration using Command Line Interface" (cli).  I am enjoying learn to use cli. But I am curious about webui as a configuring tool Cisco advertised  hence my question, which you have not answered.
Thanks for your advice
regards
Hello @J-Dread ,
I think @Richard Burts answered your question, but you must read between the lines. Everyone who is serious about learning and configuring Cisco IOS devices, will learn this by understanding command line interface.
That being said, in order to try to answer your question, can you provide the outputs of the following commands:
show version
dir
Regards, LG
*** Please Rate All Helpful Responses ***
J-Dread
I really appreciate @Richard Burts mild hint regarding best approach to studying CCNA. Reading "between the lines" he's telling me to focus on focus on learning cli command to configure cisco managed devices, which I will now do.
Regarding your queries.
 Show version output
Cisco IOS XE Software, Version 03.16.06.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 24-Jul-17 20:26 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2017 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
MOSELEY uptime is 11 minutes
Uptime for this control processor is 12 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1648108K/6147K bytes of memory.
Processor board ID FDO2214A0TG
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
 dir output
Directory of bootflash:/
11 drwx 16384 Apr 7 2018 10:30:49 +00:00 lost+found
114017 drwx 4096 Feb 5 2024 19:22:07 +00:00 .prst_sync
12 -rw- 489931744 Apr 26 2018 12:52:33 +00:00 isr4300-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin
211745 drwx 4096 Apr 7 2018 10:31:48 +00:00 .installer
195457 drwx 4096 Nov 25 2023 19:23:03 +00:00 core
244321 drwx 4096 Apr 7 2018 10:47:04 +00:00 .rollback_timer
13 -rw- 0 Apr 7 2018 10:47:14 +00:00 tracelogs.840
325761 drwx 16384 Mar 6 2024 19:03:31 +00:00 tracelogs
14 -rw- 30 Mar 6 2024 18:58:45 +00:00 throughput_monitor_params
15 -rw- 34 Dec 9 2023 20:27:23 +00:00 pnp-tech-time
16 -rw- 13815 Dec 9 2023 20:27:26 +00:00 pnp-tech-discovery-summary
3149967360 bytes total (2498310144 bytes free)
