09-28-2020 02:45 PM
So I loaded this topology backup in GNS3 and I noticed that Edge2 can't ping any of the 172.16 addresses. I was pretty sure this was working before. I've done "clear ip bgp *" on both Edge1 and Edge 2. Weirdest part to me is, Edge 2 has the routes for it, pointing at Edge1 as the next hop, but pings just won't work.
Edge1:
Gateway of last resort is 172.16.0.1 to network 0.0.0.0 S* 0.0.0.0/0 [1/0] via 172.16.0.1 10.0.0.0/8 is variably subnetted, 7 subnets, 3 masks C 10.0.0.0/30 is directly connected, GigabitEthernet2/0 L 10.0.0.2/32 is directly connected, GigabitEthernet2/0 B 10.0.0.4/30 [20/0] via 10.0.0.1, 00:48:51 B 10.0.1.0/24 [20/0] via 10.0.0.1, 00:48:51 B 10.0.2.0/24 [20/0] via 10.0.0.1, 00:48:51 B 10.0.3.0/24 [20/0] via 10.0.0.1, 00:48:51 B 10.0.4.0/24 [20/0] via 10.0.0.1, 00:48:51 172.16.0.0/16 is variably subnetted, 6 subnets, 3 masks C 172.16.0.0/30 is directly connected, GigabitEthernet1/0 L 172.16.0.2/32 is directly connected, GigabitEthernet1/0 B 172.16.1.0/24 [20/0] via 172.16.0.1, 00:47:44 B 172.16.2.0/24 [20/0] via 172.16.0.1, 00:47:44 B 172.16.3.0/24 [20/0] via 172.16.0.1, 00:47:44 B 172.16.4.0/24 [20/0] via 172.16.0.1, 00:47:44 192.168.0.0/24 is variably subnetted, 6 subnets, 3 masks C 192.168.0.0/30 is directly connected, GigabitEthernet3/0 L 192.168.0.1/32 is directly connected, GigabitEthernet3/0 O 192.168.0.4/30 [110/2] via 192.168.0.2, 00:05:39, GigabitEthernet3/0 O 192.168.0.8/30 [110/2] via 192.168.0.19, 00:29:43, GigabitEthernet4/0 C 192.168.0.16/29 is directly connected, GigabitEthernet4/0 L 192.168.0.18/32 is directly connected, GigabitEthernet4/0 O 192.168.1.0/24 [110/2] via 192.168.0.2, 00:05:39, GigabitEthernet3/0 O 192.168.2.0/24 [110/3] via 192.168.0.19, 00:29:43, GigabitEthernet4/0 [110/3] via 192.168.0.2, 00:05:39, GigabitEthernet3/0 EDGE1# EDGE1#sh run | s bgp router bgp 65000 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 10.0.0.1 remote-as 65222 neighbor 172.16.0.1 remote-as 65111 neighbor 192.168.0.19 remote-as 65000 ! address-family ipv4 neighbor 10.0.0.1 activate neighbor 172.16.0.1 activate neighbor 192.168.0.19 activate neighbor 192.168.0.19 next-hop-self exit-address-family EDGE1# EDGE1#sh ip pro *** IP Routing is NSF aware *** Routing Protocol is "ospf 1" Outgoing update filter list for all interfaces is not set Incoming update filter list for all interfaces is not set Router ID 192.168.0.18 Number of areas in this router is 1. 1 normal 0 stub 0 nssa Maximum path: 4 Routing for Networks: 192.168.0.1 0.0.0.0 area 0 192.168.0.18 0.0.0.0 area 0 Passive Interface(s): FastEthernet0/0 GigabitEthernet1/0 GigabitEthernet2/0 GigabitEthernet5/0 GigabitEthernet6/0 VoIP-Null0 Routing Information Sources: Gateway Distance Last Update 192.168.1.1 110 00:05:47 192.168.2.1 110 00:05:47 Distance: (default is 110) Routing Protocol is "bgp 65000" Outgoing update filter list for all interfaces is not set Incoming update filter list for all interfaces is not set IGP synchronization is disabled Automatic route summarization is disabled Neighbor(s): Address FiltIn FiltOut DistIn DistOut Weight RouteMap 10.0.0.1 172.16.0.1 192.168.0.19 Maximum path: 1 Routing Information Sources: Gateway Distance Last Update 10.0.0.1 20 00:49:00 172.16.0.1 20 00:46:10 Distance: external 20 internal 200 local 200 EDGE1# EDGE1#sh ip bgp BGP table version is 24, local router ID is 192.168.0.18 Status codes: s suppressed, d damped, h history, * valid, > best, i - internal, r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter, x best-external, a additional-path, c RIB-compressed, Origin codes: i - IGP, e - EGP, ? - incomplete RPKI validation codes: V valid, I invalid, N Not found Network Next Hop Metric LocPrf Weight Path r i 10.0.0.0/30 192.168.0.19 0 100 0 65222 i r> 10.0.0.1 0 0 65222 i * i 10.0.0.4/30 192.168.0.19 0 100 0 65222 i *> 10.0.0.1 0 0 65222 i * i 10.0.1.0/24 192.168.0.19 0 100 0 65222 i *> 10.0.0.1 0 0 65222 i * i 10.0.2.0/24 192.168.0.19 0 100 0 65222 i *> 10.0.0.1 0 0 65222 i * i 10.0.3.0/24 192.168.0.19 0 100 0 65222 i *> 10.0.0.1 0 0 65222 i * i 10.0.4.0/24 192.168.0.19 0 100 0 65222 i *> 10.0.0.1 0 0 65222 i r> 172.16.0.0/30 172.16.0.1 0 0 65111 i *> 172.16.1.0/24 172.16.0.1 0 0 65111 i Network Next Hop Metric LocPrf Weight Path *> 172.16.2.0/24 172.16.0.1 0 0 65111 i *> 172.16.3.0/24 172.16.0.1 0 0 65111 i *> 172.16.4.0/24 172.16.0.1 0 0 65111 i
Edge2:
Gateway of last resort is 10.0.0.5 to network 0.0.0.0 S* 0.0.0.0/0 [1/0] via 10.0.0.5 10.0.0.0/8 is variably subnetted, 7 subnets, 3 masks B 10.0.0.0/30 [20/0] via 10.0.0.5, 00:19:12 C 10.0.0.4/30 is directly connected, GigabitEthernet1/0 L 10.0.0.6/32 is directly connected, GigabitEthernet1/0 B 10.0.1.0/24 [20/0] via 10.0.0.5, 00:19:12 B 10.0.2.0/24 [20/0] via 10.0.0.5, 00:19:12 B 10.0.3.0/24 [20/0] via 10.0.0.5, 00:19:12 B 10.0.4.0/24 [20/0] via 10.0.0.5, 00:19:12 172.16.0.0/16 is variably subnetted, 5 subnets, 2 masks B 172.16.0.0/30 [200/0] via 192.168.0.18, 00:19:12 B 172.16.1.0/24 [200/0] via 192.168.0.18, 00:19:12 B 172.16.2.0/24 [200/0] via 192.168.0.18, 00:19:12 B 172.16.3.0/24 [200/0] via 192.168.0.18, 00:19:12 B 172.16.4.0/24 [200/0] via 192.168.0.18, 00:19:12 192.168.0.0/24 is variably subnetted, 6 subnets, 3 masks O 192.168.0.0/30 [110/2] via 192.168.0.18, 00:07:06, GigabitEthernet2/0 O 192.168.0.4/30 [110/2] via 192.168.0.10, 01:35:25, GigabitEthernet3/0 C 192.168.0.8/30 is directly connected, GigabitEthernet3/0 L 192.168.0.9/32 is directly connected, GigabitEthernet3/0 C 192.168.0.16/29 is directly connected, GigabitEthernet2/0 L 192.168.0.19/32 is directly connected, GigabitEthernet2/0 O 192.168.1.0/24 [110/3] via 192.168.0.18, 00:07:06, GigabitEthernet2/0 [110/3] via 192.168.0.10, 01:35:25, GigabitEthernet3/0 O 192.168.2.0/24 [110/2] via 192.168.0.10, 01:35:25, GigabitEthernet3/0 EDGE2# EDGE2#sh run | s bgp router bgp 65000 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 10.0.0.5 remote-as 65222 neighbor 192.168.0.18 remote-as 65000 ! address-family ipv4 neighbor 10.0.0.5 activate neighbor 192.168.0.18 activate neighbor 192.168.0.18 next-hop-self exit-address-family EDGE2# EDGE2#sh ip pro *** IP Routing is NSF aware *** Routing Protocol is "ospf 1" Outgoing update filter list for all interfaces is not set Incoming update filter list for all interfaces is not set Router ID 192.168.0.19 Number of areas in this router is 1. 1 normal 0 stub 0 nssa Maximum path: 4 Routing for Networks: 192.168.0.9 0.0.0.0 area 0 192.168.0.19 0.0.0.0 area 0 Passive Interface(s): FastEthernet0/0 GigabitEthernet1/0 GigabitEthernet4/0 GigabitEthernet5/0 GigabitEthernet6/0 VoIP-Null0 Routing Information Sources: Gateway Distance Last Update 192.168.1.1 110 00:07:14 192.168.2.1 110 01:35:33 192.168.0.18 110 00:07:24 Distance: (default is 110) Routing Protocol is "bgp 65000" Outgoing update filter list for all interfaces is not set Incoming update filter list for all interfaces is not set IGP synchronization is disabled Automatic route summarization is disabled Neighbor(s): Address FiltIn FiltOut DistIn DistOut Weight RouteMap 10.0.0.5 192.168.0.18 Maximum path: 1 Routing Information Sources: Gateway Distance Last Update 10.0.0.5 20 00:19:21 192.168.0.18 200 00:19:21 Distance: external 20 internal 200 local 200 EDGE2# EDGE2#sh ip bgp BGP table version is 12, local router ID is 192.168.0.19 Status codes: s suppressed, d damped, h history, * valid, > best, i - internal, r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter, x best-external, a additional-path, c RIB-compressed, Origin codes: i - IGP, e - EGP, ? - incomplete RPKI validation codes: V valid, I invalid, N Not found Network Next Hop Metric LocPrf Weight Path *> 10.0.0.0/30 10.0.0.5 0 0 65222 i * i 192.168.0.18 0 100 0 65222 i r> 10.0.0.4/30 10.0.0.5 0 0 65222 i r i 192.168.0.18 0 100 0 65222 i *> 10.0.1.0/24 10.0.0.5 0 0 65222 i * i 192.168.0.18 0 100 0 65222 i *> 10.0.2.0/24 10.0.0.5 0 0 65222 i * i 192.168.0.18 0 100 0 65222 i *> 10.0.3.0/24 10.0.0.5 0 0 65222 i * i 192.168.0.18 0 100 0 65222 i *> 10.0.4.0/24 10.0.0.5 0 0 65222 i * i 192.168.0.18 0 100 0 65222 i *>i 172.16.0.0/30 192.168.0.18 0 100 0 65111 i *>i 172.16.1.0/24 192.168.0.18 0 100 0 65111 i Network Next Hop Metric LocPrf Weight Path *>i 172.16.2.0/24 192.168.0.18 0 100 0 65111 i *>i 172.16.3.0/24 192.168.0.18 0 100 0 65111 i *>i 172.16.4.0/24 192.168.0.18 0 100 0 65111 i
Can anyone tell me what I'm doing wrong? It has the routes, so I would think pings would work. Scratching my head on this one.
09-28-2020 05:11 PM
NVM I'm stupid. Forgot about return traffic
09-28-2020 11:27 PM
Hello @WallaceVanDunk1494 ,
it is not a problem you have provided feedback on the issue.
EDGE1 needed to advertise 192.168.0.16/29 to ISP1 in eBGP session using a network command.
Hope to help
Giuseppe
