What does.....
bradlesliect
no atm ilmi-keepalive
.....mean?
This is on the atm interface of the ADSL Router. Its a 877W ADSL Router.
ankbhasi
Hi Brad,
"atm ilmi-keepalive " command is used to enable Interim Local Management Interface (ILMI) keepalives.
To disable ILMI keepalives, use the no form of this command.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/wan_r/wrabr.htm#1017985
Ankur
royalblues
Level 10
Level 10
From the command reference
atm ilmi-keepalive
To enable Interim Local Management Interface (ILMI) keepalives, use the atm ilmi-keepalive command in interface configuration mode. To disable ILMI keepalives, use the no form of this command.
atm ilmi-keepalive [seconds]
no atm ilmi-keepalive [seconds]
Syntax Description
seconds
(Optional) Number of seconds between keepalives. Values less than 3 seconds are rounded up to 3 seconds, and there is no upper limit.
Defaults 3 seconds
Command Modes
Interface configuration
Command History
Release Modification 11.0 This command was introduced.
Examples
The following example enables ILMI keepalives for the ATM interface 1/0:
interface atm 1/0
atm address-registration
atm ilmi-keepalive
HTH, rate if it does
Narayan
bjornarsb
Level 4
Level 4
When you configure VC management, you enable the router to detect VC connections and disconnections automatically. This notifies protocols to reroute packets immediately, preventing protocols from waiting for unpredictable and relatively long timeout periods. You may use Integrated Local Management Interface (ILMI) or operation, administration, and maintenance (OAM) or both for managing your PVCs, and OAM for managing your SVCs.
Bjornarsb
