04-01-2019 07:35 PM
I am trying to Nat a network 10.1.1.0/24 to another network 192.168.1.0/24. When this happens, the last octets Z should remains (e.g 10.1.1.50 to 192.168.1.50), otherwise packets will be lost. Basically it's a 1-to-1 NAT. May i know whts the steps to do this?
04-04-2019 02:17 AM - edited 04-04-2019 02:29 AM
Hello
Based on our OP queried the previous nat configuration i supplied would accommodate.
However based on what you now have explained matching host-host wouldn't be applicable or using a single static nat translation say between 172.16.8.1 -172.15.1.1 (unless this is port specific)
The reason being is your two routers have only a public /30 subnet , So each router only has 1 public ip address to nat with.
What isn't clear is if both these routers are performing nat or just rtr2 , If the latter then at most you can do is dynamic port address translation (many-to-one ) or Static (one -to-one) if they are both performing nat then your even more restricted
So to summarize based on what you have explained so far, what your asking is not possible unless the public subnet between the "wan" rtrs is expanded.
04-04-2019 06:39 PM
Only R2 is performing NAT, & it NAT all inside->outside to interface outside IP address & vice versa for return traffic. So i assume this is many-to-one NAT like overload used in Internet connection.This is source IP address NAT.I was wondering which commands i can use for this objective.
Then the second part would be Destination NAT. Sorry i confuse which command tht u provided is for dest or source NAT or both. Can u roughly specified? Like i explained, there are 2 Dest NAT, one is whole Dest network NAT, one is Single host Dest NAT. Can you enlighten me?
04-05-2019 03:58 AM - edited 04-05-2019 04:04 AM
Hello
access-list 100 deny ip host 172.16.8.1 any
access-list 100 permit ip 172.16.0.0 0.0.255.255 any
ip nat inside source list 100 interface <wan> overload
The above config in part 1 will accommodate part of this request as for 1-1 address translation to allow outside host initiate connection even when dynamic entry has timedout
access-list 101 permit ip host 172.16.8.1 host 172.15.1.1
route-map 1
description Destination-Nat-static
match ip address 101
ip nat pool LAN 10.4.44.2 10.4.22.2 netmask 255.255.255.252
ip nat inside source route-map 1 pool LAN reversible
04-05-2019 04:26 AM
HI,
Thanks for providing these cmds. Fyi, NAT destination when packets travels frm inside to outside. e.g. 172.16.7.0/24->192.168.1.0/24 & 172.16.8.1->172.15.1.1
| ip nat outside source static |
Since inside to outside.and NAT destination , shouldn't it be ip nat outside source static?
The source NAT cmds are clear enough. But how about dest network NAT of 172.16.7.0/24->192.168.1.0/24 inside to outside?
Thank you so much for helping!!
04-05-2019 04:51 AM
Hello
@getaway51 wrote:
HI,
- Translates the source of the IP packets that travel outside to inside.
- Translates the destination of the IP packets that travel inside to outside.
Has I have stated you only have on "Public" ip to work with so ip nat outside static wouldn't be applicable to use in this case hence i provided an alternative using the nat reversible feature.
Not so sure what you meant by this but the dynamic pat statement provided will translate any internal 172.16.0.0/16 (including 172.16.7.0/24) to any outside address, On the other hand if you are wishing to match host to host bit ti (outside/inside or inside/outside) between these subnets than again this isnt applicable in this case as far as I am aware.
04-05-2019 04:58 AM
Hi ,
I think there might be some confusion here. These are all destination IP not source IP.
172.16.7.0 & 172.16.8.1 are on Workstation LAN
192.168.1.0/24 & 172.15.1.1 are on HQ Servers LAN
When someone tries to access 172.16.7.0/24 & 172.16.8.1/32, R2 will NAT the destination to 192.168.1.0/24 & 172.15.1.1/32.
04-05-2019 05:08 AM
Hello
Your NAT rtr is R2 , its internal networks are 172.16.0.0/16 ( including 172.16.7.0/24) this is only where you can nat, you cannot in this case using destination nat (outside-inside) initiating from outside your nat boundary with just one public ip address to many internal addresses..
04-05-2019 05:44 AM
Hi Paul,
Let me further clarify. The destination nat needed is inside-> outside not destination nat (outside-inside). Source IP NAT is using the overload command you specified earlier(many-to-one) to outside interface source IP.
These are all destination IP not source IP. I wont worried abt source IP NAT for now.
172.16.7.0 & 172.16.8.1 are on Workstation LAN-->destination INSIDE
192.168.1.0/24 & 172.15.1.1 are on HQ Servers LAN--->destination OUTSIDE
When someone tries to access 172.16.7.0/24 & 172.16.8.1/32 frm INSIDE-->OUTSIDE, R2 will NAT the destination to 192.168.1.0/24 & 172.15.1.1/32.
04-05-2019 06:12 AM - edited 04-05-2019 06:22 AM
Hello
I think we are going around in circles here, Lets forget about the destination word for a moment and focus on your needs
172.16.7.0/24 and 172.16.8.1 are internal to your nat router 2
192.168.1.0/24 , 172.15 1.1 are outside of your nat boundary residing behind router 1
if ANY host from internal/within your nat router 2 initiates access 192.168.1.0/24 PAT will be used (inside/outside)
if ANY host from internal/within your router1 trys to initiate access towards 172.16.0.0/16 ( including 172.16.7.0/24) this cannot be done with the setup you have.
On aside note I have provided a solution in which you could statically initiate an host to host outside/inside connection (< rtr1-trt2 >) using the nat reversible feature.
Apart from the above unless i am mistaken I don't see any other scenario that can be accomplished here.
04-05-2019 06:25 AM
Hi Paul,
Apologize for the confusion here. As I m trying to understand 100% of whats happening from every angle.
172.16.7.0/24 and 172.16.8.1 are internal to your nat router 2---yes you are right
192.168.1.0/24 , 172.15 1.1 are outside of your nat boundary residing behind router 1---yes you are right
---yes you are right about PAT but they will be accessing 172.16.7.0/24 and 172.16.8.1 from internal not 192.168.1.0/24 & 172.15 1.1. 192.168.1.0/24 & 172.15 1.1 is after R2 NAT inside->outside.
if ANY host from internal/within your router1 trys to initiate access towards 172.16.0.0/16 ( including 172.16.7.0/24) this cannot be done with the setup you have.--Perhaps let me change something here.LAN became 10.1.1.1/24. When someone tries to access destination 172.16.7.0/24 and 172.16.8.1, R2 NAT destination to 192.168.1.0/24 & 172.15 1.1/32. At the same time source IP NAT to OUTSIDE interface IP due to overload command. Is this not doable?
Am I correct with these explanations?
04-05-2019 06:58 AM
Hello
No need to apologies i am glad you trying to understand it , maybe my wording could be better, anyway..
@getaway51 wrote:
Hi Paul,
Any internal communication between any host in 172.16.0.0/16 WONT be subject to any network translation ONLY traffic communication that need to traverse your public interface (which has the ip nat outside appended to it) will be subject to nat - Hence (inside-to outside)
I am sorry I dont understand what you are trying to ask-
What do you mean by LAN became 10.1.1.1/24 what LAN -are you on abort transit path between r1 - r2 became /24 subnet ?
04-05-2019 07:20 AM
Let me try explain in diagram the setup.
Servers LAN HQ-------------R1----------------------R2---------------------------PC
192.168.1.0/24 10.4.4.1(LAN) 10.4.4.2(OUTSIDE) 10.1.1.5
172.15 1.1/32 10.1.1.1/24(INSIDE)
PC telnet to destination 172.16.7.0/24 and 172.16.8.1/32. PC source wil became 10.4.4.2 due to NAT in R2. Assuming tht all routing is done. All traffic travels from PC to Servers LAN & return back to PC. No initiation from Servers LAN to PC.
Based on this scenario, what would the cmd be? At least I can clearly differentiate each cli based on objective
04-05-2019 08:55 AM
Hello
From the looks of it your pc resides on the same side of the network its trying to connect to is that correct ?
if that is the case then as I have already stated NO translation will take place.
04-05-2019 09:33 AM
04-05-2019 10:50 AM
Hello
if a is pc behind behind R2 and it initiates a connection to ANY device internally NO nat is performed
if a pc is behind R2 ( private network) and it initiates a connection to ANY device externally then nat is perfromed and the return traffic from that iniciation is allowed back in due to the dynamic nat entry that will exist in the nat table ( this return traffic you can say is a form of destination nat) whenever that nat entry expires the outside host cannot return any traffic or iniciate anyother traffic flow unless another nat entry is created by the iniside host from the private network
Destination nat is when a host externally ( not on the private network like internet) try’s to a connect to host behind s nat boundary (private network) and the original destination address that this external host uses is translated into a private host address in that private network
