what is the limitation on number of PPTP connections to Cisco 1751
boris.kotlarsky
We need to find out what is the limitation on number of PPTP connections (no mppe encryption is required)
to a Cisco 1751 router?
Are there any default values that need to be changed in order to support 100
concurrent PPTP connections.
wong34539
Level 6
Level 6
To the best of my knowledge, IOS has limitation that you can't clone more than 5 virtual access interfaces off of a virtual -template with a static ip address on it..
