08-21-2010 08:41 AM - edited 03-04-2019 09:30 AM
I have an internet connection to comcast. When I look at the interface stats on my cable interface I see a lot of output drops. What could be causing this? Here is the results from a "sh int c0/0/0 from my router:
Robrouter#sh int c0/0/0
Cable-Modem0/0/0 is up, line protocol is up
HFC state is OPERATIONAL, HFC MAC address is 0018.19b6.5de4
Hardware is Cable modem, address is 0014.1cc1.8973 (bia 0014.1cc1.8973)
Description: WAN - Internet
Internet address is 75.75.32.157/22
MTU 1500 bytes, BW 768 Kbit/sec, DLY 13020 usec,
reliability 255/255, txload 1/255, rxload 3/255
Keepalive not supported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/5/0 (size/max/drops/flushes); Total output drops: 135577
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1 minute input rate 12000 bits/sec, 15 packets/sec
1 minute output rate 3000 bits/sec, 3 packets/sec
HFC input: 0 errors, 0 discards, 0 unknown protocols 0 flow control discards
HFC output: 0 errors, 135411 discards
36280225 packets input, 4281026903 bytes, 75 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 2 throttles
2186322 packets output, 1518696830 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Thanks in advance
Solved! Go to Solution.
08-21-2010 09:24 AM
First of all, you do not have a very high drop rate, just about one in 200.
The reason is that transmit speed on cable interface is not very high, router is reporting 768 Kbps., consequently when you upload much data, it is normal that there the queue fills up and there are drops.
You can try increasing a little hold-queue out on the interface, however that will not prevent drops under continued upload.
08-21-2010 09:24 AM
