What's problem about the infor?
haijason
Hi,My 7507 suddenly display the following information:
Feb 20 05:01:08: %CI-2-ENVCRIT: +24 Voltage measured at 12.64
Feb 20 05:01:11: %CI-4-ENVWARN: 2.5 Reference measured at 1.36
I used the show environment all to check it:
Rwanzhou7507-2#sh environment all
Arbiter type 1, backplane type 7507 (id 4)
Power supply #1 is 700W AC (id 2), power supply #2 is 700W AC (id 2)
Active fault conditions: none
Active trip points: none
15 of 15 soft shutdowns remaining before hard shutdown
0123456
Dbus slots: XX XX
card inlet hotpoint exhaust
RSP(2) -79C/-110 -59C/-74F -47C/-52F
Shutdown temperature source is 'hotpoint' on RSP(2), requested RSP(2)
+12V measured at 5.99
+5V measured at 2.50
-12V measured at -6.01
+24V measured at 12.07
+2.5 reference is 1.25
Rwanzhou7507-2# sh env
Rwanzhou7507-2# sh environment ta
Rwanzhou7507-2# sh environment table
Sample Point LowCritical LowWarning HighWarning HighCritical
RSP(2) Inlet 44C/111F 50C/122F
RSP(2) Hotpoint 54C/129F 60C/140F
RSP(2) Exhaust
RSP(3) Inlet 44C/111F 50C/122F
RSP(3) Hotpoint 54C/129F 60C/140F
RSP(3) Exhaust
+12 Voltage 10.90 11.61 12.82 13.38
+5 Voltage 4.61 4.94 5.46 5.70
-12 Voltage -10.15 -10.76 -13.25 -13.86
+24 Voltage 20.38 21.51 26.42 27.65
2.5 Reference 2.43 2.51
Shutdown boards at 70C/158F
Shutdown power supplies at 76C/168F
Restart after shutdown below 40C/104F
Pls help me to confirm what problem is?
Thanks a lot!
mrmozaffari
The above messages indicate the voltage measured by the CI card. The following are the most likely triggers for these messages:
""A faulty power supply?If you have a spare power supply available, install it in either of the power supply bays and verify that the error messages disappear. If, after replacing the power supply, the errors still occur, the CI card is the next thing to check .""
""A faulty CI card?If the router has two power supplies, and the combined bus voltages are low, the cause cannot be a power supply problem. In the Cisco 7500 architecture, one power supply cannot drag down the output voltage of another; isolation diodes prevent this from happening. A faulty CI card is the most likely cause. Open a case with the TAC for further troubleshooting.""
Best Regards Bahman Mozaffari.
Please Rate if Helpful.
