What SPA to use for ATM DS3 on ASR1000 Routers?
hsbcadmin
Am trying to find out what is the suitable SPA for ASR1000 routers to connect ATM DS3 through the local telco. Currently this is connected to a NM-ATM-DS3 module on a C3845 router. The reason for asking is we need to upgrade the WAN router to ASR1000. Hope someone can help.
Thanks.
Chang W K
Giuseppe Larosa
Hello Chang,
no ATM DS3 SPA is listed for ASR 1000
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/data_sheet_c78-443175_ps9343_Products_Data_Sheet.html
I'm sorry to give you bad news
or you upgrade the access circuit to OC-3 or you cannot connect the ATM line to the ASR 1000, or you would need an external ATM switch to perform speed adaptation
Hope to help
Giuseppe
Giuseppe Larosa
Hello Chang,
Hope to help
Giuseppe
Hi Giuseppe,
That was my conclusion as well after browsing the Cisco docs for half a day. Just wanted confirmation in case I missed something.
Thanks for your advice.
Cheers
Chang W K
