what to advertise in BGP on p2p links
carl_townshend
Hi all
when I have my 2 internet routers that each connect to a separate ISP routers with /30 links to each, do I need to advertise these /30 links in the BGP network statement? will the ISP also advertise these or do I just need to do it on my routers?
cheers
Raju Sekharan
Hi Carl
You need to advertise only the public prefix pool allocated to you which you want to advertise
You don't need to advertise the connected /30 interface. ISP will take care of it
Hi Carl,
i would advertise as reference for your IGP.
Alessio
Update: on both the ends regardless the functional configuration (active, passive - primary secondary, primary primary and so on..)
Would I only do this on one end normally or both ?
cheers
Carl
