when will cisco update IOS 15.2.2T for 2900??
Optiver BV
Hi all,
latest IOS version is from 18Nov11 and with little amount of traffic it keeps cpu usage sky-high until it starts losing packets (I've tried performance fine tuning according to cisco webpages and saw little difference)
Downgrading isn't an option as 15.2.1 version doesn't implement everything I need...
so... when is it due the new version?
Thanks in advance!
Eugene Khabarov
Level 7
Level 7
It is not latest version. Train doesn't mean that it is latest. Check downloads and you will find fe 15.0(1)m8 that was released yesterday
Hi Eugene, I know: I meant latest from 15.2.2 as all others seem not to support multicast over switched interfaces, which a requirement on my setup. Can you please confirm whether 15.0(1)m8 would support multicast over switched interfaces?
Thanks!
please check cisco.com/go/fn for required feature. It will give you an answer.
thanks, I did before I posted, this image isn't there yet.
