Which Cisco Router for 6xT1
lzcczd2000
What Cisco Router would I use to terminate 6xT1?  Complete with Cards please.
Leo Laohoo
What is your WAN bandwidth?
I am trying to create a template for all the options so let's just assume it is for the full 9M.  I think the biggest variable here is that I need to have a router with a card that can terminate all 6 T1's.
Don't assume.  Not all routers can support X Mbps.   This question about the WAN speed is very important because you can't run a "template".  Each router can do X amount of bandwidth due to financial reasons.  Again, the question is this:  What is/are the WAN bandwidth(s)?
Only the 800-series router will NOT support T1 line cards.
A list of different routers (ISR G2) and supported line cards (T1) can be found HERE.
