Which ios version should i be using ?
kwarren7677
Which ios version should i be using for my 2610 & 2611 routers. I was told they have been sitting since 2003. Thanks for any help.
The current version is:
Router>sh version
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(5a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 25-Nov-03 06:00 by kellythw
Image text-base: 0x80008098, data-base: 0x819E4F8C
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 23 minutes
System image file is "flash:c2600-ik9o3s3-mz.123-5a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 2610 (MPC860) processor (revision 0x203) with 61440K/4096K bytes of memory.
Processor board ID JAD04120FJT (3900742936)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
jhalldn
Hi, i've checked with Cisco FN and your running IOS 12.3 IP/FW/IDS PLUS IPSEC 3DES BASIC. If you still need all of that features (feature-set), i would probably go with the GD-release and with this platform and it looks like 12.2(26c)...12.3 seems to have Release Deferred.
This platform has done it's job and maybe you should look into swap them to something new and wonderful.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If the router's IOS version meet your needs, then you might consider keeping to the same IOS train, but just migrating to the latest of it.  (The latter, in theory, would be the most bug free.)
