which IOS ?
bapatsubodh
hi,
If router fails to boot from nvrom and is going to rommon mode continously.
This is due to corroupt flash. how to decide which IOs needs to be downloaded from CISCO.com and to be stored back to
FALSH of router.
thanx.
thisisshanky
Level 11
Level 11
If you want to download the same IOS, do a dir flash: command from rommon and then you can find out the version number and feature set. For ex:
If the file name starts with,
c2600-is-mz --> The i stands for IP feature set and the S indicates its IP Plus.
After the mz, you should start seeing the version number.
"124-5a.bin" -- Indicates 12.4.5a IOS version.
Use this link to download. You will need CCO login and password.
http://www.cisco.com/kobayashi/sw-center/sw-ios.shtml
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
jarathbu
For general IOS features and requirements for your hardware you can use the Cisco Feature Navigator (requires CCO login)
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Recovering the image you can use either tftpdnld method (quickest) or XMODEM.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094a0b.shtml
Hope this helps.
