Which is best cisco 891 or 892
Mero Cisco
Which router is better 891 or 892, what is the difference between them and which one is cheaper and by how much ?
My requirement is to run about 10-20 computers from each router.
Mero
Leo Laohoo
The difference between the two is the backup services.
892 has ISDN dial backup while the 891 is for V.92.
What to get depends entire upon what you require.
Cisco 890 Series Integrated Services Routers
8 Replies 8
Leo Laohoo
Thanks Leolahoo,
I don't need any of those backup links, I want the cheaper one, what do you suggest ?
What are you trying to do?
890 has an 8-port switch so you'll need to buy a Layer-2 switch.
If a router is what you need and you have a tight budget, try Cisco Refurbished.  How many VLANs are you planning to use?
I am planning to use 3-4 vlans only
3-4 VLANs only?  Try the 860.
anooshoks
Good
And what is your WAN bandwidth link?
256 kbps to 1 mbps depends on site.
Actually I am looking for router with 1-2 routing ports and 16-24 managable switching ports in the same box and it must support IPsec, any suggestion
