Which power cable for India - 1841?
ian.potts
I can't find which power cable to use for an 1841 in India?
Can you please tell me which one I should order?
Many Thanks
sbilgi
Level 5
Level 5
Power Cable specification must be a Universal standard.Connect the 1841 router to a 15 A, 120 VAC (10 A, 240 VAC) circuit with overcurrent protection. The input voltage tolerance limits for AC power are 85 and 264 VAC.Get a Power Cable that meets the above mentioned parameters.Refer the URL below http://www.cisco.com/en/US/products/ps5853/products_installation_guide_chapter09186a00802c36a5.html
ananddiwakar
In addition to the above post, please make sure that you change the top of cable to a 3 pin one (Generally all the cisco devcies are shipped with 2 pin connector which does not have a ground conection). Using a 3 pin connector provides you the grounding connection plus the connector will fit perfectly in the plug point.
