09-13-2018 01:39 PM - edited 03-05-2019 10:55 AM
which router can handle upto 200 NAT translation as the same time? i am looking for new cisco router which can translate 200 IP addresses (Natting) at the same time.
09-13-2018 01:47 PM
the short answer is: any router, even the most low end router, can handle 200 concurrent NAT translations. One NAT translation uses about 312 bytes of memory, so even the low end 800 series with 512MB default DRAM memory can easy handle that...
09-13-2018 02:00 PM
Look at the ASR Model start with below link
https://www.cisco.com/c/en/us/products/routers/asr-1001-x-router/index.html
09-13-2018 03:17 PM
Don't just look at the NAT capabilities. It is important to know what is the WAN speed and whether or not the router can support this speed or not.
