12-21-2020 01:24 AM
Hi fams, I tried troubleshooting pc2 inside the firewall to ping HQ router, Laptop at satellite office to ping firewall, and ISP router to ping firewall, but none of which works. it seems like packets cant ping from Changi router to firewall is causing the issue, but I still can't figure out why. Please help me, imma gonna break down :(. Below is the attached pkt file with vlsm table , password and username for routers is cisco, no password has been configured on the firewall
Solved! Go to Solution.
12-22-2020 01:13 AM
I configured OSPF on the ASA as well. I had to erase the configs from the HQ router and the ASA and start from scratch, so some things might be missing. You now have end-to-end connectivity.
Attached the revised file.
12-21-2020 04:32 AM
is this actually a task with required settings, and if so, can you post the entire project requirements ?
12-21-2020 06:31 AM
12-21-2020 09:25 AM
there is nothing in the documeny that says anything about IP addressing, or routing (protocols), or NAT ? So I guess all you need is end-to-end connecivity ?
12-21-2020 04:19 PM
Hello ,
Routing protocol needs to be OSPF. No requirement for ip address . Yup all needs to have end to end connectivity
12-22-2020 01:13 AM
12-22-2020 04:31 AM - edited 12-22-2020 04:31 AM
Hello, Thank you so much georg!
