05-27-2022 06:19 AM - last edited on 05-31-2022 06:30 AM by Translator
R1 is not routing the packets with destination 172.16.23.x which is subnet for R3
No packets are going past R1
Only policy applied to outbound interface is DSCP marking policy, and so I am not sure why it is not routing traffic beyond R1
Topology
Ipv4 header
From Switch ALS1 to R1 the Wireshark output
There doesn't seem to be IPV4 header
here is packet view from traffic generator showing dest 172.16.23.3
R1 is no routing packets
Can someone help me fix this
Here's output R1 run
Current configuration : 2000 bytes
! Last configuration change at 06:41:17 EST Fri May 27 2022
! NVRAM config last updated at 04:49:25 EST Fri May 27 2022
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone EST -5
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip tcp synwait-time 5
class-map match-any critical
match protocol eigrp
match protocol ntp
class-map match-any interactive
match protocol telnet
match protocol ssh
match protocol xwindows
class-map match-any web
match protocol http
match protocol pop3
match protocol netbios
policy-map Marking
class interactive
set precedence 5
class critical
set precedence 5
class web
set precedence 3
class class-default
set precedence 1
interface FastEthernet0/0
ip address 172.16.10.1 255.255.255.0
ip nbar protocol-discovery
duplex half
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
ip address 172.16.12.1 255.255.255.0
clock rate 79841
service-policy output Marking
router eigrp 1
network 172.16.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.12.2
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
ntp logging
ntp master
ntp server 172.16.10.1
end
Solved! Go to Solution.
05-27-2022 07:19 AM
Hi @hfakoor222 ,
The issue seems to be at the origin. There's a few things wrong with the generated IP packets.
- The destination MAC address (08:00:00:00:00:00:00)
- The ether type (00c1). It should be 0800 for IPv4.
05-27-2022 06:28 AM - last edited on 05-31-2022 06:06 AM by Translator
I dont think problem is in R1 as it has default route to R2.
The problem can be in R2 or in the link between R1 and R2. I saw this is a serial link but I did not see you using any encapsulation on the interface.
05-27-2022 06:46 AM - last edited on 05-31-2022 06:08 AM by Translator
Hmm why would encapsulation be important here?
after encapsulation of hdcl on each s1/3 interface of R2 and R1 the output from wireshark is showing no traffic
Btw here is run for R2
#sh run
Building configuration...
Current configuration : 1850 bytes
! Last configuration change at 04:46:57 EST Fri May 27 2022
! NVRAM config last updated at 04:49:21 EST Fri May 27 2022
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
class-map match-any prec5
match precedence 5
class-map match-all prec0
class-map match-all prec1
match precedence 1
class-map match-all prec3
policy-map llqpolicy
class prec5
priority percent 15
class prec3
bandwidth percent 30
class prec1
bandwidth percent 20
class class-default
fair-queue
no ip address
shutdown
duplex half
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
ip address 172.16.23.2 255.255.255.0
clock rate 128000
service-policy output llqpolicy
interface Serial1/3
ip address 172.16.12.2 255.255.255.0
clock rate 79841
router eigrp 1
network 172.16.0.0
no auto-summary
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
05-27-2022 06:54 AM - last edited on 05-31-2022 06:15 AM by Translator
Well, probably it is using HDLC by default but I preffer enable PPP. Anyway, on router 2, do you have a route send to R1?
R2:
ip route 172.16.10.0 255.255.255.0 172.16.12.1
05-27-2022 07:06 AM - last edited on 05-31-2022 06:25 AM by Translator
did you mean to type 172.16.12.1 255.255.255.0 172.16.12.1?
It seem the f0/0 interface is not receiving extra packets when I run the traffic generator
05-27-2022 07:22 AM
You are trying to send traffc to network 172.16.23.x from 172.16.10.x, correct?
What about the routing in R2?
05-27-2022 07:31 AM
I see what you are saying now, thank you that is good advice for next time
05-27-2022 07:19 AM
Hi @hfakoor222 ,
05-27-2022 07:22 AM
now that I think of it I put R3 mac as dest mac address and not R1
05-27-2022 07:27 AM - edited 05-27-2022 07:32 AM
After changing mac address from R3 to R1 Dest traffic is now being routed, and i can focus on my QOS labbing.
Thank you very much Harold i appreciate it
05-27-2022 07:21 AM - last edited on 05-31-2022 06:20 AM by Translator
It looks like your running EIGRP.
2 things.
Have all 3 routers formed a neighorship?
Can you provide the output of
show ip route
on all routers?
You can also try running a ping from R1 F0/0 interface to R3 network. If it reaches then you have basic connectivity. This could point to an issue between your R1 F0/0 interface and traffic generator. If this is a simulator then it could just be buggy.
-David
