Why would OSPF be preferred over BGP over a tunnel network
Hi All
I have routers connected from one site to another using OSPF over a tunnel.
I have configured new tunnels using EBGP by manipulating the local-as
A lot of my subnets have gone over to the new BGP tunnels as they have an admin of 20 vs 110
However some are still going via OPSF and when look at show ip bgp output
the origin is shown as IGP (as oppoased to incomplete) and there is a wieight of 32768
Thanks for your help
Harold Ritter
Hi @JamesSimpson34554 ,
The weight of 32768 means the prefix is being locally originated, rather than received from the BGP peer. It looks like you might be redistributing OSPF in BGP. If so, make sure you do not redistribute the OSPF routes that were previously received via the tunnel into BGP.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi Harold,
I am redistributing OSPF into BGP, its strange as I have a number of subnets that are now being seen by the routers in BGP, there are a select few that are still prefering to go over the OSPF tunnel
It is a race condition. It depends if the BGP or OSPF update is learnt first. As suggested before, make sure you apply proper filtering in place.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
can you post the full configs of both routers ?
